1999 Volvo V70XC Hard Start - Check Valve install Topic is solved
Fuel System Check Valve Installation P80 Volvos
- Has thanked: 2652 times
- Been thanked: 1242 times
Re: 1999 Volvo V70XC Hard Start - Check Valve install
Seboroth, good write-up and photos! This in in the Volvo Repair Database, and I made your account "Contributor".
Seboroth_V70XC
- Year and Model: Volvo V70XC 1999
Thank you very much! I'll keep contributing as much as I can.
robbiewilso
- Year and Model: V70 2000 XC SE
- Has thanked: 2 times
Followed your pictorial pretty much exactly and have no leaks (YAHH!) and will hopefully have better starts. The fittings I went with are pretty much exactly as pictured and if I ever have to redo the fuel pump I can replace this contraption with a standard fuel filter easily! Thanks for doing all the hard work of figuring it out.
Update- 24 hours later and several successful starts after sitting for hours/overnight. No more killing the starter! Thanks again for the superb pictorial and step by step. I used a dremel with a cutoff wheel to shorten the inlet port and cut off the barbed end of the outlet. I actually put a thin strip of rag inside it to make sure no metal shavings got into the filter itself.
- 2769 Views
Last post by jimmy57
- 1303 Views
Last post by RickHaleParker
