Yes...that's the only time the light will be triggered.DePonce wrote:...the coolant level...is just a hair below the min line - will this trigger the coolant light?
'99 S70 Engine Temperature Indicator
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Thanks! got some OEM stuff on the way.
I understand this is a close system, how much loss is expected over time if there are no leaks on the system? gee this car is 15 years old and I cant remember adding coolant since I bought in 99
Current: 1999 S70/manual transmission - from new, working on 115K miles
Former: 1985 740 GLE/manual transmission - from new to 250 miles!
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
None. Well, very very little. Check the cap as well - they sometimes split in half.DePonce wrote:Thanks! got some OEM stuff on the way.
It's time for a cooling system flush for sure. I would find the leak and overhaul the rubber hoses as well.
If you smell coolant when you use the heater, the heater core is also a common leak point as these cars age.
'98 S70 T5
2016 Chevy Cruze Premier
By the way, any pics to help in identifying potential leaks on the heater core?
I found some videos on YT, I believe I have a heater core leak! One tip is the unexplained sticky stuff on some of the controls on my door, etc! Crap!
jblackburn
That's fairly normal for these cars; it's just a coating on the switches that wears off.One tip is the unexplained sticky stuff on some of the controls on my door, etc! Crap!
Do you smell coolant when the heater's run? Is the carpet near the gas pedal wet?
'98 S70 T5
Thanks. So the sitcky stuff on switches/controls on doors and dash has nothing to do with leaking/fume residue from coolant? By the way, what's the best way to clean this w/o further damaging the original plastic/rubber?jblackburn wrote:That's fairly normal for these cars; it's just a coating on the switches that wears off.One tip is the unexplained sticky stuff on some of the controls on my door, etc! Crap!
My sense of smell is not as acute as compared to my wife's
Thanks again!
jblackburn
Nope, no relation whatsoever. A bad heater core may also make a consistent, annoying film on the inside of the windshield that comes back soon after cleaning.
Go to the bottom of this thread:
https://www.matthewsvolvosite.com/forums ... 29&t=34056
I haven't tried it myself, but worth a shot.
'98 S70 T5
Good info! I'll keep an eye on my windshield. Thanks again!jblackburn wrote:Nope, no relation whatsoever. A bad heater core may also make a consistent, annoying film on the inside of the windshield that comes back soon after cleaning.
- 4748 Views
Last post by EChem
- 573 Views
Last post by Smith
- 754 Views
- 1829 Views
Last post by jblackburn
- 831 Views
Last post by s10lowrider1994
