98 V70 GLT. Changed heater core still foggy
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
A slow leak won't cause your windshield to fog up. The system is designed to use the AC as the dehumidifier to keep the windows from fogging up. This is especially important in colder climate. So, start the car, turn the system on defrost, open the hood, look at the compressor to see if the clutch is engaged. If it is not, your windows will not defog unless the air going to it is very warm/hot. You may also want to make sure air is being directed to the windshield.
stephansvolvo
- Year and Model: V70 GLT 1998
- Has thanked: 21 times
- Been thanked: 3 times
Not to sound slow.....but where is the compressor located and how can I tell if the clutch is engaged?rspi wrote:A slow leak won't cause your windshield to fog up. The system is designed to use the AC as the dehumidifier to keep the windows from fogging up. This is especially important in colder climate. So, start the car, turn the system on defrost, open the hood, look at the compressor to see if the clutch is engaged. If it is not, your windows will not defog unless the air going to it is very warm/hot. You may also want to make sure air is being directed to the windshield.
I'm getting air to the windshield. I'm going to clean the crap out of the windows tomorrow as I'll be in it anyway figuring out why I got misfires in all 5 cylinders today.
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
- Has thanked: 311 times
- Been thanked: 817 times
The A/C compressor has an electromagnetic clutch on it. So the compressor pulley always turns, but the compressor itself is only engaged when the AC is on. So you will see the innards spin when the AC is on, but only the pulley spins when it is off. I wonder if rspi made a video of this, it is a good topic for a video. The gap enlarges over time, on these pre-98 cars the gaps are pretty much all quite wide, often to big. You can fix it pretty easily with 3 zip ties.
stephansvolvo
RSPI has a video of a/c compressor shim. Maybe I'll take a look at that.
Thanks Erik
Thanks Erik
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
- 751 Views
- 32 Replies
- 17667 Views
Last post by sleddriver
- 1298 Views
Last post by E Showell
- 11 Replies
- 9808 Views
- 5065 Views
