Changed out my heater core a few weeks ago and it took care of the smell and fogging. Yay! Now I am getting fogging on the windows, not like before. I clean them and they have that hazy look again. Any thoughts on this?
Also my heat output is lacking since the switch. There was a post earlier today with this same issue. I'll keep tabs on that post but anything here I'll take too!
As always thanks folks
98 V70 GLT. Changed heater core still foggy
stephansvolvo
- Year and Model: V70 GLT 1998
- Has thanked: 21 times
- Been thanked: 3 times
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
kahl
- Year and Model: 2000V70XC
- Been thanked: 10 times
when I R & R my heater core I had to take the carpet out of the car and wash both sides to get most of the antifreeze out. Also pulled out the fiber board sound deading material and gently washed. I was surprised how much of the antifreeze was trapped in the layers. The neat thing was 20 years of coffee spills helped turn the carpeting from sun fade orange closer to the original tan color.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Isn't by chance ...the REC button on heater console on?
If it is...it MUST be off.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Is the AC compressor working?
- phils94850
- Year and Model: 2009 s60 turbo
Id agree.. probably need to make sure you don't have any antifreeze residue..
1996 Platinum Edition
stephansvolvo
All good things. Its off recirc. When I did the exchange I pressed down on the sound proof and it was dry. No puddles or antifreeze residue visible. As far as the ac compressor, it seems like it cycles. Although I haven't had to use the ac in the last few weeks, as it is Colorado. I will double check all these things. What's the best way to check the ac compressor?
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
- dosbricks
- Year and Model: '96 855, '98 S70
- Been thanked: 4 times
Stephan, did you drive the car to check for any leaks at the connections at core or firewall before you buttoned up the interior panels? The plastic junction at the firewall has been known to crack when core is R&R. I replaced my junction out of caution, but it seemed in fine condition.
stephansvolvo
I let the car run to temp and gave it a little gas and didn't notice any leaks at the core. I didn't check at the fire wall. I will do that tomorrow as I plan on pulling it apart to verify I did it right.dosbricks wrote:Stephan, did you drive the car to check for any leaks at the connections at core or firewall before you buttoned up the interior panels? The plastic junction at the firewall has been known to crack when core is R&R. I replaced my junction out of caution, but it seemed in fine condition.
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
kahl
hi Stephan, before going to the trouble of removing core stuff some paper towels around the tubes and under the heater box. Pull them out in a few days and see if they are wet. This is how I found a slow leak on my Nephew's V70.
stephansvolvo
Kahl....that's a great tip. Thankskahl wrote:hi Stephan, before going to the trouble of removing core stuff some paper towels around the tubes and under the heater box. Pull them out in a few days and see if they are wet. This is how I found a slow leak on my Nephew's V70.
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
- 748 Views
- 32 Replies
- 17614 Views
Last post by sleddriver
- 1298 Views
Last post by E Showell
- 11 Replies
- 9794 Views
- 5058 Views
