Replacing rotors
This topic is in the MVS Volvo Repair Database » Brake Pad and Rotor Job Checklist & Tutorial
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Thanks a lot gentlemen. Do I have to compress the caliper or anything before I take it off, or do I just pull them off?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I normally need to pry the piston back, at least partially, to remove the caliper. If I am replacing the rotors at the same time I just use a big hurkin screwdriver and push the pistons on the calipers all the way back without fear of any damage to the old rotors. If I am keeping the old rotors I use a little more finesse and just get them clear enough to get the calipers and pads off and then re-compress the caliper piston when they are off so as to not damage the rotor.
C@lvin
Been thanked: 2 times
Post by C@lvin »
Hey Lee, I've always read the the time to change the pads is at 3MM and the rotor has 23MM min. thickness stamped on the edge.
I've got 5MM left on my front pads but my rotors are right at 23MM. Since the rotors are still smooth with no warping I was thinking I'd just keep going until I got at or below 3MM on the pads and then change them both out at that time. Do you see any problem with that?
Also, I'm already at 3mm on the rear pads (didn't measure the rotor but it has a pretty good lip on it) but was thinking, as long as I keep an eye on it, I might sqeak out another thousand or two miles before changing them. Is that a bad idea?
Calvin
98 S70
00 V70
240,245,760,940,850 Turbo
Post by Ozark Lee »
I wouldn't have a problem with changing the pads and just leaving the rotors as they are if they aren't yet warped. I normally get 2 full sets of pads out of a set of rotors. I might get even better since I went to the drilled rotors on all of the cars.
iselloil
Year and Model: 1999 V70 XC AWD
Post by iselloil »
Autozone has the ceramic pads with rubber backing,so no grease needed.
1999 V70 XC
1999 V70 under constuction,or
destruction from previous owner
Mobil 1
K & N Filters
Ceramic brakes
Volgrrr
Year and Model: '95 T5 wagon
Post by Volgrrr »
Just be a little cautious.
I recently did set out to change the pads on my T5, having done this a number of times on other vehicles I've owned previously.
Bing in a bit of a hurry, I jumped under the T5, undid two fair sized bolts at the rear of the backing plate and, to my surprise, hydraulic oil started to pour out.
I'd carelessly undid the bolts that hold the caliper together - not the bolts that hold the calipers onto the back plate. There probably are other cars out there with split calipers, but this was the first one I'd run into.
However, the brakes are fixed now and I will be more careful in future to ensure I'm taking out the actual caliper holding bolts - not any old bolt that happens to be poking out of the backing plate.
You live and learn.
There are only two types of car owners - those who own Volvos and those who wish they did.
polskamafia mjl
I went to a parts store and asked for brake grease and the guy looked at me like I was crazy. What does the brake grease actually do...and is there another a name for it? haha
JFO
Year and Model: '98 S70 GLT
Post by JFO »
He should have known what you were after. It's just silicone grease, a standard material used on the back of pads, shims, caliper slides. Brands include SylGlide and Plastilube.
Jim
'98 S70 Turbo GLT
280,000 km
Post by Ozark Lee »
Alternatively I have used a Permatex product called Disk Brake Quiet. It is kinda like an RTV paste but it has worked OK in lieu of the SilGlyde. Nearly any auto parts store will have the Permatex stuff.
tailor
Year and Model: 2004 XC90 2.5T AWD
Post by tailor »
https://www.matthewsvolvosite.com/forums ... &sk=t&sd=a
The above post is full of great bits of information with regard to rotors and pad replacement and the pros and cons of "turning" rotors. As well as the "bedding" process.
1994 850 Auto Turbo wagon 306000km (Sold)
2004 XC90 AWD 188000km
"Life is like a reel to reel tape recorder,
the closer you get to the end,
the faster it spins."
Abe Gottschalk
