1986 240 DL Fuel pump fuse bypassed?
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
mhgreen
Year and Model: 240 DL 1986
Re: 1986 240 DL Fuel pump fuse bypassed?
Post by mhgreen »
93Regina wrote:
Now, does OP know where relay is found, or even have an understanding of relevant electrical circuits?
According to my Haynes manual, the relay is under the steering column, above the fuse panel. I do not have an understanding of 'relevant electrical circuits'.
“Some cannot loosen their own chains and can nonetheless redeem their friends.”
rgk
Year and Model: Gray 88 245
Has thanked: 1 time
Post by rgk »
93Regina wrote:
rgk wrote:Would this also apply to having a different year/model's relay connected?
Really getting off topic on this topic...a relay is required, unless one wants to fry their ignition switch.
How is that off-topic? I've had this problem before and have wondered whether perhaps having a slightly different relay, one that still allows the car to run, might cause such a problem.
rgk -- was dickdeadly
rgk
Has thanked: 1 time
Post by rgk »
The relay is found in the passenger foot rest area, behind the carpet, sort of under/behind the glove box.
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
mhgreen wrote:the relay is ...
When you think about a relay, Google "Volvo Relay"
and click on "Volvo Relays - DaveBarton.com"
and then scroll down the page until you find: Here are some diagrams I've collected showing RELAY LOCATIONS for Volvo 240, 700 and 900 models.
93Regina
Post by 93Regina »
rgk wrote:How is that off-topic?
Relays have a function, and ignition switches can't deal with the heat (aka amps) generated via fuel pump circuit.
It would take someone who does not know Jack-Shiiit to bypass the safety function of OEM's relay setup; and if someone had the know-how, they would grab correct part from a JY vehicle.
Jerry-rigged volvos are few/far between...
Since OP did not asked relevant questions, yet at that time, location and testing of relay terminals, I concluded your comment was a Non sequitur
mhgreen
Post by mhgreen »
Okay. Evidently the relay for the fuel pump is behind/under the glove box on the passenger side. What do I do with this information?
93Regina
Post by 93Regina »
mhgreen wrote:What do I do with this information?
Read it: Volvo Relays - DaveBarton.com
93Regina
Post by 93Regina »
Remove fuel pump relay...get its part number and google it...is it the right relay?
Leave fuel pump relay out, can you start the vehicle with it removed?
mhgreen
Post by mhgreen »
Car will not start with relay disconnected. Just tried it.
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
Did you put the original relay back in and save the new one for later?
1988 Volvo 760 Turbo Wagon
