2001 V70XC - VIDA DiCE is useless...
JDS60R
- Been thanked: 3 times
A sharp knock that only occurs before the engine starting and then "never" occurs while running can be caused by a failing coil pack . As it continues to fail it is usually accompanied by an unexplained slightly rough idle or an occasional jerk while driving. Then the coil pack finally fails and a misfire will indicate its position. It can also be a fractured or bad spark plug .
Retired
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
The metal-to-metal was present this morning before the start.JDS60R wrote:A sharp knock that only occurs before the engine starting and then "never" occurs while running can be caused by a failing coil pack . As it continues to fail it is usually accompanied by an unexplained slightly rough idle or an occasional jerk while driving. Then the coil pack finally fails and a misfire will indicate its position. It can also be a fractured or bad spark plug .
All 5 ignition coils were replaced in September 2014, and the spark plugs are close to 2 years -- Ignition Coil IPD HD , and Volvo spark plugs, respectively.
- 16563 Views
Last post by xiaofei204716
- 19238 Views
Last post by jonesg
- 7161 Views
Last post by Klem
- 10814 Views
Last post by jonesg
- 5962 Views
