Yes this is what we found.They often leak from the seams but that is more of a weeping than a leaking.
2002 XC70 AW55-50SN Transmission swap with 04 S60 55-51SN
boneman131
- Year and Model: XC70 2002
Sorry, I'm referring to the 'skid pan' (?) that bolts on under the car, under the engine/trans. Have to remove it to change oil filter, see underside of engine/trans.
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
What color did the leak has? ATF is red. If you are talking about leaking junction between engine and transmission, that's engine's rear seal pushed out by excessive crankcase pressure caused by clogged crankcase ventilation.
boneman131
UPDATE: We ended up selling the vehicle to someone who wanted to, and had experience, to tackle trying to fix the transmission. He contacted me a few weeks later informing me that he had fixed the trans, and it's issues were due to a cracked forward clutch drum. He was able to weld the drum and used the clutches from the spare transmission we had purchased and included.
precopster
- Year and Model: Lots
- Been thanked: 128 times
My XC '01 has a cracked first gear drum which I'm in the process of repairing. Also many of the frictions were almost down to metal. We had no reverse as a symptom. It's great to hear when people revive these units.
- Locky2001V70
- Year and Model: v70 P2 2001
- Has thanked: 1 time
This sounds like very similar symptoms in our 2001 V70.
The loss of fluid was causing barely any grab in 1 st gear until speed picked up.
However in our case the transmission was heavily leaking fluid. I managed to drive it 2kms to our house where it is now "resting".
We purchased a 2004 2.5T as we loved the practicality and safety's the V70's.
Just still deciding if I attempt to get the 2001 going again to get it through rego!
jakeman1111
- Year and Model: v40
Looking to do similar with a 2001 V70XC with well over 200,000 miles. An initial attempt to renew valve body was stopped due Seriously Corroded valve body cover torx screws. While sub-frame was dropped poor condition of all sub-frame/motor mounts was revealed. At least I was able to take care of those issues.
Now looking for a tranny to rebuild (Wife's car, no down time allowed)
The gobs of excess orange RTV bore witness to the fact that prior transmission work had been done (prior to my ownership). The up shot of this is that an AW55-50SN had been installed in lieu of the factory specified AW55-51SN. I do not know what the installer had to do software wise. The 50SN gave us no trouble over the 7 years we have owned the car until typical valve body issues arose. :
- 2565 Views
Last post by jimmy57
- 1325 Views
Last post by dadyer
- 5975 Views
Last post by Tone944
- 11 Replies
- 16721 Views
Last post by precopster
- 1387 Views
Last post by Tsquared
