2000,S70, Starting Issue
- Has thanked: 1507 times
- Been thanked: 3825 times
Re: 2000,S70, Starting Issue
A big leak of unmetered air into an ME7 car can cause a no-start. Keep driving it to confirm. I think you nailed it
My starting issue is resolved...but Lee is correct that the PO442 code for the evap leak continues to re-appear and must be a separate issue that needs to be addressed. If I can't find any obvious vacuum leaks I will probably need to go the smoke test route. Is there a good write up for that procedure? I did find a video that outlines how to make a homemade smoke tester... using incense, a paint can, and a propane gas regulator.
2008, C70, 44,000 miles
2000, S70, GLT, 67,000 miles
1995, 850, GLT, 144,000 Miles
1996, 850, Turbo, 226,000 Miles (TMU)
