2000 S70 - Accidentally put in full synthetic oil
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Sit back and enjoy improved fuel economy.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- dosbricks
- Year and Model: '96 855, '98 S70
- Been thanked: 4 times
I purchased my wagon when it was two years old and switched it to full synthetic. It took about two years for the synthetic to clean up some brown deposits inside the engine, so it doesn't happen overnight. The S70 has always been on synthetic since initial break-in.
JRL
- Year and Model: Several
- Been thanked: 16 times
You should have been running synthetic anyway but now at your miles check for any leaks in a few hundred miles.
If it has no leaks, continue to run it.
precopster
- Year and Model: Lots
- Been thanked: 128 times
I'm going to stick my neck out (again)
The theory that sludge can form a leak barrier which is more effective than a seal itself is just poppycock and I don't buy it. Fresh oil is still touching seals where an engine has sludge because that part is spinning/moving and opening galleyways for the oil to flow there.
Unless the seal is fully encapsulated in sludge I really do not see how a leak can be prevented. If that were the case parts would be grinding down into little metal pieces......though I have heard of sludge causing this in extreme cases.
If the car starts leaking after a change to synthetic it would have started leaking in any case. When a car has 140K miles plus things just go wrong.........
I'd better get my umbrella out now because I think its going to start raining insults
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
Mike makes a lot of good points. Also, he used "poppycock" in a sentence, and is therefore the winner anyway.
+1 to what Mike said.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- Has thanked: 1611 times
- Been thanked: 4072 times
It is indeed an internet rule that the first to use ' poppycock' closes the thread.
Oil change threads on uncivilized boards are as bad as politics and religion.
I moved my fleet of 5 cars from Dino to full synthetic over the last couple years. No leaks, itches, or scratches.
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
You accidentally did your car a favor. Stay with the full synthetic.
- 41 Replies
- 5858 Views
Last post by Ou2mame
- 23 Replies
- 4825 Views
Last post by polskamafia mjl
- 1583 Views
Last post by vtl
- 3102 Views
Last post by Uree
- 24 Replies
- 7670 Views
