it's not esoteric knowledge, it's making yourself familiar with what you're working on, and that's their responsibility.
This is literally the first result in google for "aw55 fill plug"
http://www.sonnax.com/articles/209-aw-5 ... nformation
I would get an estimate from another shop that is capable of doing the repair, and hand them the bill.
That's not being mean or spiteful, that's having them pay for their mistake, nothing more.
If you opt to have them attempt to restore the band anchor, get their admission of fault in writing, and get a timeline and expected outcome.
That way if it goes badly you'll have something to force their hand. otherwise they may tell you to bugger off when the time comes to put a new transmission in it because they hosed it attempting a repair.
2000 V70 CC - that no 3rd gear thing
John850GLT
- Year and Model: 2000 V70R
Azure blue,
Ever try the hollow bolt?
precopster
- Year and Model: Lots
- Been thanked: 128 times
Remove the B4 servo cover and piston which is located near the LHS front wheel. This prevents the piston from pushing the band about 5 degrees anti clockwise.
Then use the Swedespeed method as above with a holed bolt. About 45 minutes' work.
Removing the side cover is about 10-12 hours of work so generally avoid this method.
- 980 Views
Last post by atomic928
- 503 Views
Last post by draser
- 406 Views
Last post by yanga001
- 1474 Views
Last post by precopster
- 1014 Views
Last post by ThommyKent
