Because they don't want you messing with it while it is under warranty. If they were so confident that the fluid is good forever, why don't they put a lifetime warranty on the trans?kw1999 wrote:If the transmission fluid can/should be changed, why does the owner's manual call for no servicing of the fluid?
1995 850 GLT Transmission Fluid Service
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
- misha
- Has thanked: 155 times
- Been thanked: 432 times
When it's under warranty you CAN'T mess with anything on the car or you loose warranty.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 311 times
- Been thanked: 817 times
There is no filter to change! Just drain and fill. The drain plug is magnetic there will be a thin layer of metal sludge on it; wipe it off.kw1999 wrote:Thank you very much for all of that information. No need for a filter change?
- 714 Views
Last post by tryingbe
- 595 Views
Last post by kw1999
- 1928 Views
Last post by mf70
- 2071 Views
Last post by MrGruffles
- 1922 Views
Last post by psamanni
