I beg to differ misha. The ports are different on the head for the VVIS manifold. It does not match the teardrop shape of the '94.5 and later.
I own two vehicles with VVIS and three '95 to '98.
I would agree to keep the exhaust manifold because the '93 has a "donut" gasket connection to the down tube.
1993 850 GLT engine swap compatibility
Ben850
- Been thanked: 7 times
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Since i have no experience beyond that i heard about it....and ben850 allready have this type of 850....i assume that he knows what he is talking about.
But...i still cannot understand that heads for the same type(B5254) of engine can be different.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
cohomology
- Year and Model: 1999 v70
is there a VIN cut number for the '94.5 thing? and is it practical to put in a '94.5 or later engine in it?Ben850 wrote:I beg to differ misha. The ports are different on the head for the VVIS manifold. It does not match the teardrop shape of the '94.5 and later.
anyway I went ahead and picked up the 93 b/c it is a stick(so rare where I live) and only paid $100. I would start looking for a replacement engine now.
Ben850
Here are the two manifolds for comparison.
The VVIS is top. You can see the vanes inside that alter the air flow.
- misha
I see the difference but there is also a different shaped manifold gasket to compensate that.
I would wait for other opinion for clarification.B5254 is B5254.....B5204 is B5204 and that's the end of story.
I just want to say again that i saw with my own eyes that engine from '98 v70 was installed into '92 850 which had 2.5 20v engine.Manifolds and sensors were transfered from original engine and it ran without problems.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Year and Model: Many Volvos
- Been thanked: 76 times
The engine will run without the ports matching perfectly so long as the holes are centered the same but it won't run as well as it would otherwise.
When I raced boats we ground out and polished the ports to gain performance. It took hundreds of hours to do it by hand and get them gleaming like a mirror but that is how you get the trophy.
Ben850
I had built a couple Chevy Big Blocks and would match up the ports with a Dremel as well when I changed manifolds. The heads were ported and polished so I had needed to match the manifolds.Ozark Lee wrote:The engine will run without the ports matching perfectly so long as the holes are centered the same but it won't run as well as it would otherwise.
When I raced boats we ground out and polished the ports to gain performance. It took hundreds of hours to do it by hand and get them gleaming like a mirror but that is how you get the trophy.![]()
You had mentioned boats. One of my big blocks was a 454 racing Marine block punched .125 to a 482. I stuffed it in my '69 Camaro. Dyno tested at 650 hp.
cohomology
Thank you Ben for the very helpful information. Based on the discussion, I guess I could live with the performance loss and just drop in an engine from a later model.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
http://www.volvopartswebstore.com/produ ... earchTerm=
check your engine serial number on the timing cover against the breaks listed on these illustrations.
Current Volvos:
Ben850
I do not believe there would be any loss of performance. leave the intake manifold on the replacement engine. Utilize the existing exhaust manifold from the '93 for above mentioned reason.cohomology wrote:Thank you Ben for the very helpful information. Based on the discussion, I guess I could live with the performance loss and just drop in an engine from a later model.
A few sensors may need to be changed, but up to '96 N/A should swap in, possibly with better performance.
If you find another '93 to '94.5 for a direct swap, look at this thread of the possible tweeks I had done.
https://www.matthewsvolvosite.com/forums ... 35&t=47157
