see #19 in graphic http://www.volvopartswebstore.com/showA ... evel=11155
It's either liquid filled, or heavy metal.
1998 xc-70 mystery part to me
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Current Volvos:
Clockboy
- Year and Model: 05 xc70, v70 2.5t 06
- Has thanked: 2 times
Oscillation damper it is. Would never have guessed that one. Thanks for letting me know. It's one of those parts that I only noticed because it's covered in oil and gunk as a result of seepage from the that turbo return line leak. Like to know what I'm cleaning off.
- FLXC90
Come on down to Florida, You can learn lots under my car!!
Current Volvos:
Ringo
- Year and Model: 2006 70XC
- Has thanked: 33 times
the part number is 9480153 and it is listed as an "oscillation damper" (there is a 2nd one mounted on the side of the Angle gear case). It is shown in this diagram as #18 in the first slide.
I was curious about it too and someone else has asked on the MVS board. Evidently it is a "box of rubber". viewtopic.php?t=62446
2006 XC70 2.5T auto (B5254T2) 125K 2nd owner
1999 V70 XC 2.4T auto (B5254T) 250K Trans failed 2018
1967 122S 2-door auto (B18B) 125K (ex-wife got it 1991)
benpineapple
- Year and Model: '06 V50 T5, '13 XC90
- Has thanked: 5 times
- Been thanked: 4 times
If I were you, I wouldn't remove the flat case/cover on it. Could be a nightmare getting back together upside down. That entire damper can be unbolted from the bevel gear without removing the bevel gear from the trans itself. If I recall correctly from when i did trans seals a couple months back, the damper is held on by 3 14mm bolts on the bottom.
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
- 2242 Views
Last post by Ozark Lee
- 736 Views
Last post by askperry
- 3063 Views
Last post by BaronVonAnt
- 1678 Views
Last post by cptkosmos
- 664 Views
Last post by wizechatmgr
