99 S70 AWD Angle gear seals on trans side leaking
Big Will
- Year and Model: 1998 V70 AWD
What I can't remember is if seal # 3 in the diagram can be replaced without removing the crown nut? The o-ring can't be replaced without doing so but I can't remember. The OP's problem sounds like it's with the driveshaft seal which can be popped out with a long flathead as mentioned above or the green o-ring which is installed inside the sleeve if I remember.
98 V70 AWD - M58 Gearbox - Beüst custome tune, 20T turbo w/angled exhaust housing, Green injectors, Öhlins Roadholding Suspension, B MAC Built Engine
- 536 Views
Last post by SuperHerman
- 830 Views
Last post by JRL
- 1148 Views
Last post by JRL
- 1278 Views
Last post by FLXC90
- 2080 Views
Last post by Bamseclub
