Careful with those mounts. There is another at the LH rear corner of the trans on an AWD, and the upper mount may not be the correct one for a 2000 V70 XC. That is not the mount on my 2000 V70R. The crankshaft mount is also not the one shown.
http://www.ipdusa.com/products/7392/112 ... 70-v70-awd
Crankshaft mount
http://www.ipdusa.com/products/7257/112 ... 70-v70-awd
LH rear mount at trans
http://www.ipdusa.com/products/8078/115 ... izer-mount
Top torque mount
Finally the lower torque mount is not correct for a P80 AWD according to the FCP listing.
2000 V70 XC is a poly upper mount really a good idea?
- Has thanked: 2200 times
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
So I'm back to replacing the upper torque rod bushing on my '98 V70. I last did the bushing a few years back, probably close in time to my engine replacement -- which would have been 3 years and 60,000 miles ago. Has anybody had one of the original rubber style mounts last more than 60K miles? It feels like every time I look under the hood that bushing is on its way out. I know that isn't the case, but they sure do seem to wear out quickly. Any thoughts on that?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Been thanked: 504 times
The factory Upper Mount Lemforder is about 60K. Basically it cracks from the fore and aft motion of the engine torquing back and forth.
A ghetto fix is to fill the voids (the fore and aft voids) with silicone caulk.
- E Showell
I'll keep the improvised improvement in mind. Thanks.
'95 855 auto (sold)
'95 855 auto (sold)
- Has thanked: 311 times
- Been thanked: 817 times
They wear out quickly. I think at 60k you were very fortunate, on my cars the OEM mount lasts more like 40k. Maybe because I don't drive so many miles per year.
- E Showell
Erik -- Either I'm very lucky, or not very observant. Could be it wore out long ago and I just never noticed!
'95 855 auto (sold)
'95 855 auto (sold)
- dosbricks
- Year and Model: '96 855, '98 S70
- Been thanked: 4 times
Those Lemforders are sure hard to squeeze in there. I have a couple of thick oak blocks--one of which is milled on one side to draw it through just enough to center it--using a long 1/2" bolt. I'm wondering if it would be worth it to put the mount in the freezer overnight and if it would stay cold long enough to make installing it a bit easier. Anybody try this?
Yes Dos, that freezer trick has been recommended before, many people swear by it ... great minds think alike!
https://www.matthewsvolvosite.com/forums ... hp?t=43089
etc.
etc.
The freezer trick helps, but even with oil and by the time I have the bearing adapter in place to go, the Lemforder bushing is probably at room temp anyway.
It is still a big pain to press it in, and I only got it 80% of the way in the the bearing adapter just stops!
Next time, I will sand the bushing O.D. a tiny bit so it slides in easier. They over-design the thing too tight, no need to!
I have a belt sander so I can remove a bit of stuff on the Outer Diameter.
- 17 Replies
- 10372 Views
Last post by volvolugnut
- 909 Views
Last post by GreenMagicMan
- 3931 Views
Last post by FlyingVolvo
- 5506 Views
Last post by chitownV
- 28 Replies
- 2671 Views
