1996 850 B5202S engine oil/spark plugs
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
It's ok Erik, everyone's entitled to an opinion :)
If you read my thread I have tried multi prong NGKs for non turbos with no dramas. I can't believe that Volvo make their own plugs in the Volvo factory. There MUST be a manufacturer that supplies for them. If it's not the NGKs I mentioned, then they are a pretty good match for the OEM multi prongs.
For turbos the factory fits single prong so that is an entirely different conversation.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
cn90 wrote:I don't know if you can get NGK Iridium in Denmark, but give it a try.
I installed the NGK Iridium BKR6EIX in my Volvos (1998 S70 and 2005 XC90).
Great spark plugs, good for 80K-100K miles.
Detail below...
DIY: 2005 XC90 2.5T Spark Plugs using NGK Iridium BKR6EIX
https://www.matthewsvolvosite.com/forums ... hp?t=64080
I know you love those plugs. So you recommend them for non-turbos now, too?
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
NGK website lists Iridium (among others) for both turbo and non-turbo.
https://www.ngk.com/Automotive-NGK-l1411.aspx
Teddy1975
Year and Model: 2007 V50
Has thanked: 1 time
Been thanked: 7 times
Post by Teddy1975 »
Heh, I like when you get a bit of a discussion out of asking a question.
So to summarize the info I got from here, multi-prong plugs are bad, unless they are either Volvo OE or NGK. The NGK will be more expensive ($55 incl intl shipping) for me to get here than the Volvo OEs ($35, no shipping required), so I'll get the OE.
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
Post by erikv11 »
cn90 wrote:NGK website lists Iridium (among others) for both turbo and non-turbo. ...
LOL yes, of course NGK recommends a plug from their factory. I asked if *you* are recommending them; so you are saying the reason you do is because NGK does?? Not a big deal, just curious.
Post by cn90 »
Yes,
We discussed this topic many times here:
- NGK Copper $2/each: lifespan about 25K.
- NGK Iridium $7/each, lifespan about 100K.
I have photos of NGK Copper at 30K, the gap has widened.
I have photos of NGK Iridium at 60K: gap is still within spec. However, even when using Iridium, I usually remove them at 50K just to clean the spark plugs threads, applying antiseize to prevent galling, and re-install them. At 100K, I replace them.
From the material $ stand point, it costs the same over 100K, but the gradual deterioration has a negative effect on fuel economy that is not obvious to people, so people lose money from inefficient combustion of gasoline.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
precopster wrote:... I can't believe that Volvo make their own plugs in the Volvo factory. There MUST be a manufacturer that supplies for them. If it's not the NGKs I mentioned, then they are a pretty good match for the OEM multi prongs....
Yes there is a manufacturer who supplies Volvo with spark plugs.It's French Eyquem.
Eyquem # RFC 52 LS3.
On spark plug itself (on metal round part)is stamped 9146775 which is Oem Volvo No.for triple prong Volvo spark plugs. ;)
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Post by erikv11 »
cn90 wrote:Yes, ...
Alas, I am facing multiple fails to get my point across in this thread :?:
I will try to spell out my question, all in one post:
You seem to love NGK Iridium BKR6EIX.
You have recommended NGK Iridium BKR6EIX strongly for turbo motors.
Do you now recommend NGK Iridium BKR6EIX for non-turbo motors, too?
This question is not at all about why you love the NGK iridiums, it is about fitment. That's all, just one question, thanks!
Post by cn90 »
Yes in one word.
Post by erikv11 »
Thank you! I am surprised it is the same plug with or without turbo, very interesting, good to know.
