Fae is aftermarket part.Don't waste your time and money because it will not work properly.
It MUST be OEM VOLVO or at least VERNET.Oem ect is around 50$.
Re: 98 S70, N/A, P0116 and P0117... car will not start, again
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
Hey phils94850, I cleared the codes yesterday. I checked today before I cranked and there was nothing pending. (This is with the $10 Autel portable scanner.) I will give it a go with my $70 Autel later today and see what I get.phils94850 wrote:Did you clear the codes after installing the new ECT ? I believe thats the one misha is talking about, it should be the one next to the thermostat housing.
Would you suggest pushing it down the street and seeing if I can jump start it?
Retired:
2015 Volvo S60, T5, 85K
- phils94850
- Year and Model: 2009 s60 turbo
No.. i wouldnt do that, it should start while cranking. I think you need to check the timing belt and then do a compression test it sounds like its cranking over very easy, actually to easy
1996 Platinum Edition
- misha
It could picked up a lawnmower syndrom because of failed ect.
Too much fuel in cylinders from cranking the engine with a bad ect.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- theWIFES_S70
That's what I was thinking, too. I'll crank over the engine a few times and see if I still have timing... Thanks for the suggestions, phils94850.phils94850 wrote:No.. i wouldnt do that, it should start while cranking. I think you need to check the timing belt and then do a compression test it sounds like its cranking over very easy, actually to easy
Misha, I know it's only fifty bucks. But as it stands, we've spent a little over a dollar per mile on this car... I was hoping to save a little. I understand FAE will fail in a year or two or three. But I can live with that. That being said, perhaps you're right. Will definitely put getting the OEM one on the list possible parts to get.
Retired:
- misha
It is not about how long it will last....it will send wrong values to ecu right out from the box.
Aftermarket sensors just don't work in these cars.
Thats the point.
Thats the point.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- phils94850
As misha said it could be lawn mower syndrome. Compeession test will tell you what you need to know
- theWIFES_S70
Thanks phils94850 and misha, I will attempt to lawnmower fix it. And then get a compression test in there. I feel like the key is the sound... How did the cranking change sound like that? I imagine the engine is flooded with fuel. (I tried to crank it at least two dozen times, maybe a little more. I was hopeful... It felt like it wanted to turn over a few times...) I'll post pictures of the plugs and compression readings and anything the computer tells me when I get it.
Harbor Freight has a decent compression kit, right?
Again, many thanks...
onward...
onward...
Retired:
- misha
Put a compression testing aside for now.
Let's go with ect and lawnmover syndrom fix first.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- phils94850
I would fix your compression issue first ( if you have one ) .. you can replace the ECT but without compression it wont start anyways. The reason I'm saying do a compression test is so you don't waste your money on another ECT. If you have a serious problem then you just wasted money. You do however need to make sure its firing the injectors while cranking. You also need to "smell" you engine oil, if you did wash out the cylinders you probably have contaminated your engine oil so youll need to do an oil change if it smells like gas.
I would put a cap full of engine oil down each cylinder, make sure its getting fuel while cranking, clean your spark plugs while there out, and then try to start. If after doing that, it still sounds the same I would do a compression test. I do agree with Misha, I think you cranking it washed out your cylinders causing the sound you have now. I think you do the lawnmower fix, itll start.
Yes, harbor freight has a cheap compression tester, that's where I got mine from...
Did you ever check the timing belt ?
- 859 Views
Last post by Dingo957
- 2384 Views
Last post by mar601
- 1820 Views
Last post by Samtara1
- 13 Replies
- 3931 Views
Last post by MrAl
- 902 Views
Last post by Vancethevolvo
