V70 base transmission issues after seal replacement
- dosbricks
- Year and Model: '96 855, '98 S70
- Been thanked: 4 times
Torque converter was improperly installed.jwegman wrote: I don't recall it clunking into place, but I bolted it to the flywheel/ motor and then slid the transmission over it.
My TC install: see minute 6:46 on the video.
- Has thanked: 311 times
- Been thanked: 817 times
Great video, nicely shows a properly seated torque converter. Kudos to Robert and Ken.
- dosbricks
Kudos to Robert for help/supervision and video. Also to wheelsup for this great engine pull tutorial.
https://www.matthewsvolvosite.com/forums ... =1&t=28973
precopster
- Year and Model: Lots
- Been thanked: 128 times
I smashed the rear cover plate out of a AW50-42LE by bolting the torque converter to the driveplate/flywheel first about 3 years ago.
Wished I had picked that up on first read
You need to fit the torque converter to the transmission spline and then carefully insert the transmission onto the engine until the proper clearance is reached (this is viewable through the starter hole)
Thanks for the help! I'm up and running again.
I ended up ordering a pump and torque converter off ebay as both were messed up from the improper install.
I even put it together right!
All in all it was an expensive learning process but I cut my time in half doing it the second time.
This is one post among many others.EstVolvo wrote:"I realized my fluid was low and topped it off with the toyota type IV as recommended."
Who recommended to us it in a AW50/42LE?
http://www.volvoxc.com/forums/showthrea ... oyota-T-IV
- 2058 Views
Last post by wizechatmgr
- 9727 Views
Last post by tyguyc
- 17 Replies
- 4886 Views
- 2143 Views
Last post by SonicAdventure
- 1311 Views
