Do I need a single from the CAN bus or the PWM signal from the accelerator, or could I simply connect the power source directly to the plug of the ETM?
Thanks for your support,
Sebastian
ETM Question
TonyatXeMODeX
- Year and Model: 2007 S60
Yes you can run a power supply directly to the plug for the ETM. Make sure it is a switched power supply ( only activated when the ignition is in the second key position), then your CAN signal and PWM will still be active.
Regards,
Tony
Regards,
Tony
- 497 Views
- 4699 Views
Last post by ajwsurfer
- 5165 Views
Last post by antonevane
- 15 Replies
- 6893 Views
- 4820 Views
Last post by firstv70volvo
