OK, so time to consider my options.
I could just sell the car for maybe $500. Look around and pickup a similar car for similar price. $2500-$3000 out of pocket.
Replace with Volvo rebuilt transmission. $3500-4000 out of pocket.
Replace torque converter with Volvo unit. $1000-1500 out of pocket.
Does anyone know if the torque converter from other AW55-50SN applications fits a Volvo unit? If so, those are a dime a dozen.
Side note, as an engineer at an original equipment manufacturer myself, it's maddening to me that one transmission can have the same part number but a myriad of minor differences in applications. Give them different part numbers if they're different!
2001 V70 T5 Auto transaxle problems
01_Nautic_V70
- Year and Model: 2008 XC90 V8
- Been thanked: 8 times
JRL
- Year and Model: Several
- Been thanked: 16 times
Valvebody not torque converter
You can't really just replace a converter, if that is shot, the rest of the tranny is shot .....and most of the labor is the same anyway
You can use a 2002 tranny but it's almost as bad as a 2001
2003 and up transmission is not a direct bolt inm some electrical parts must be changed.
Again, where are you located?
I can get a valvebody rebuilt and WITH LABOR to R&R it for about $600
You remove the valvebody and send it to me, I can have it rebuilt for $400 (you pay for shipping, both ways on top of that.
(You can pay retail and buy a reman V/B for 6 to $800)
Complete tranny rebuild with R&R included for under $3K
Obviously with a guarantee/warranty
01_Nautic_V70
I'm in the St Louis, Missouri area.
Wouldn't the "sitting in drive, throttle wide open and no motion" indicate the torque converter is junked? Would replacing the valvebody help me? Whichever route I go, I'll do the removal/install myself.
01_Nautic_V70
So the plan for the weekend is to drain and inspect the fluid for shavings/bits of metal and/or friction material. The fluid in there is only about 2 weeks old, so if' it's loaded up with anything, it's a harbinger that a grenade went off in the internals. If all looks good with the fluid, but I have no motion, does that point to valvebody? I'd think a catastophic failure of the torque converter resulting in no power transfer would load up the fluid with junk too, right?
So the troubleshooting will be: Look at fluid. If it's loaded up with bits, the transmission is coming out. If it's not, start removing that valvebody.
Anyone who's been through this have any advice or further instruction?
no, not always.01_Nautic_V70 wrote:I'm in the St Louis, Missouri area.
you'd need to tap into the pressure test ports to verify that the torque converter is spinning the input, and thus spinning the pump.
it's quite possible a failed VB is not engaging the pistons to actuate the bands in the transmission, or worn piston bores let enough fluid past that they don't hold pressure well enough to engage the bands.
this sonnax document is excellent for troubleshooting.
http://www.sonnax.com/articles/209-aw-5 ... nformation
01_Nautic_V70
Ah, thanks. I know I'm getting ahead of myself, but if I get this transmission fixed, that stop-neutral software has to come out. I had read in another thread that one user had successfully installed the tcm firmware upgrade without a dealer? True?nsjames wrote:no, not always.
01_Nautic_V70
First findings this morning. Fluid looks healthy and debris free. Bright red and nothing on the drain plug when I wiped it. Interestingly, the tip of the dipstick is gone. Could that have been sucked into the valvebody passages to block line pressure?
Next up, I need to pull this valvebody out.
01_Nautic_V70
Dare I ask where the pump pickup is located?
01_Nautic_V70
So after running all of the fluid I could drain through a coffee filter, nary one shaving or bit of clutch material or metal was present. So I don't think the internals of the transmission itself were harmed. That leads me to believe the valve body is jacked up and apparently there's a blockage in line pressure somewhere. I've cleared all of the obstructions out of the way and supported the engine with a hoist. Tomorrow, I'll drop the subframe and pull the valve body cover and body itself. Then it's p for debate whether to try and rebuild myself or to have it rebuilt.
- 1375 Views
Last post by Ozark Lee
- 1660 Views
Last post by MadeInJapan
- 889 Views
Last post by theWIFES_S70
- 15 Replies
- 2073 Views
- 741 Views
Last post by Nadiamarie22
