98 S70 N/A M56 Manual stainless steel shifter bushing replacement
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
WhatAmIDoing wrote:Looks like something I can actually do myself. Hoping this will fix some of my inconsistent shifting issues.
Absolutely. It's a great $10 fix! (Unless of course you have all sorts of fancy hoses and clips lying around! :mrgreen: )
Here's a Youtube tutorial of the process. Anyone can do this. You don't even need any sandpaper, just lube it up.
Retired:
2015 Volvo S60, T5, 85K
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
OK -- I'm sensing the start of a new feature -- the "MVS McGyver Challenge." I'm thinking the first marker has already been laid down. . . And the paperclip-to-replace-fuel-pump-relay has already been ruled ineligible.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Has thanked: 1610 times
Been thanked: 4065 times
Is this a repair you've done or one you've seen? Warning...I've spent a lot of time in Eastern Europe.
Redox
Year and Model: 1997 Volvo 850
Post by Redox »
Sorry to ressurect an old thread but I have a question. Does anyone know the outside diameter of the bushing, not the lip but the contact surface, and also the inside diameter. I used to have them in my old 850 and wondering if I can use them for another application (2006 Mazda 6). The bushings cant be replaced either. It looks close in size but want to be 100% Thanks!
I think I would try messaging the ebay seller - s/he is probably motivated to expand the market of use!!
theWIFES_S70
abscate wrote: 10 May 2017, 12:14 I think I would try messaging the ebay seller - s/he is probably motivated to expand the market of use!!
+1!!
Retired:
Winnebago
Year and Model: 98 V70 T5M-R
Post by Winnebago »
OD = ~22mm. I will try to get an ID tonight.
FWIW: I got these... can't really tell a difference. had brass bushings for a few hundred miles (came with the car) and they were nice and green.
https://www.kaplhenke.com/collections/8 ... t-bearings
'98 V70 T5M - lots of R parts - 201k+miles
'98 S70 GLT - bought new. sold at 185k miles
Redox
Post by Redox »
Ok thanks for the info! Looks like my diameter is about 26mm.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Man, you guys are amazing. When I installed my cables a few weeks ago and felt the movement in my cable end bushings, I thought that was a good thing. But my shifting feels knotchy to 2nd and a little in 3rd. I guess I need to give this a try to get that smooth solid feel.
baxtex
Year and Model: Volvo S70 99
Has thanked: 1 time
Post by baxtex »
Do anyone know of the dimensions of a replacement bushing? I just looked at Roberts video about this:
He just used some generic skateboard ball bearing and I made a search on ebay. Some posts above this says the outer diameter is 22mm and I made a search on ebay for skateboard ball bearings 22mm. Almost every bearing that cam up is 22mm outer, 8mm inner and 7 width/lip. Could those fit? I could go out to my car and measure the existing ones, but I'm afraid that I'd break them if I take them off and then I can't shift until I get new ones. :D
