850 won't start unless gas pedal is pressed while cranking
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Sounds like a classic failed engine coolant temperature sensor. The car thinks its very cold so it dumps extra fuel in to enrich the mixture for starting. The only way to clear to extra fuel is to depress the gas pedal -- sounds counterintuitive I know, but it isn't. If you change the ECT, then also change the thermostat.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
Thanks for the advice, I will continue to investigate. I still suspect it to be the fuel injector relay. The clip on mine was broken off and it was floating around which probably made it come loose over time. I going to clean out the MAF when I get chance as well as check the CPS.
- 802 Views
Last post by Steele1
- 13 Replies
- 2254 Views
Last post by misha
- 14 Replies
- 3466 Views
Last post by dj_v70
- 1503 Views
Last post by xHeart
- 1373 Views
Last post by Anthony303
