1999 V70 T5 Incident Report MAF Turbo (FIx: Induction Leak) Topic is solved
Has thanked: 2202 times
Been thanked: 1852 times
Glad it was that easy! It is great when an issue turns out to be a relatively cheap and easy fix.
Well done that man!
Has thanked: 1610 times
Been thanked: 4068 times
Notes on repair. I did swap in the new MAF before I caught the boost pipe fitment problem. Tugging off the MAF I pulled off the air cleaner induction pipe off the turbo way too easily, and sure enough I did not have a good fitment on that connection.
Put the PCV purge hose on first before connecting to the turbo...on the 1999 there is a lot of tension on the PCV hose. Make sure the PCV clamp grabs the hose and not the plastic ridge on the induction hose
Make sure clamp isnt compressing plastic boss instead of soft pipe
I used SS clamps ( worm drive) and got them nice and tight. They do boost up to pressure, of course
I put the old MAF back in and now have a known to be good spare Bosch MAF
For posterior - here were the reported codes from the induction hose leak - neither code had anything to do with failure.
Also added picture of plastic boss/PTC nipple detail above.
Last bumped by abscate on 23 Mar 2020, 08:51.
