What Brand of Premium Fuel Do You Use?
kippster41493
Year and Model: 1994 850
Post by kippster41493 »
I use recommended octane mainly at Mobil gas stations, I've noticed any of my euro cars like Mobil better for what ever reason. I did try a tank of the highest octane V-Power at Shell though and it seemed to actually run better. Going to do another trial tank on next fill up (been using Mobil for a few tanks now) and see if I get the same experience and not just a placebo run again.
1994 850 2.3 Turbo :D
1998 V70 GLT 2.5 Turbo :shock: - project now
1995 BMW 530i :)
1998 Eclipse GSR - 3.5" off the ground and headers
Has thanked: 1610 times
Been thanked: 4068 times
Never mix Mobil and Shell. People behind you will appreciate it.
kippster41493
abscate wrote:Never mix Mobil and Shell. People behind you will appreciate it.
I usually get it pretty empty (about a gallon or so left) out of curiosity why are you not supposed to mix the brands?
1995 BMW 530i :)
shaker_chi
Year and Model: 94 850, 98 S70T5 M
Has thanked: 3 times
Been thanked: 3 times
Post by shaker_chi »
I've shared this story in the past, but it is relevant again for this post. I used to work for Sam's Club in the Chicago market and the last store I ran had a gas station. We had our annual weights and measures inspection from the State of Illinois and we dispensed a gallon of gas in a container from each pump. I asked the inspector what they do with the gas and he replied they test it for purity and octane level to ensure accuracy to what is posted on the pump. Naturally, I had to ask which gas is the best and he replied without any hesitation Shell is by far the highest quality gas. He told me that the actual octane rating for Shell is typically 2 or 3 points higher than what is posted on the pump. He told me most fuels they test are either spot on or +-1. Not sure if this would apply to the entire country, but should hold true in Illinois.
Eddie G
You get Schmell.
Another satisfied MVS customer.....
(This pun purloined from Click and Clack the Tappet brothers from NPR)
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Sunoco 93
You should never let a tank get below 1/4 if you can help it
kippster41493
JRL wrote:Sunoco 93
If you were referring to me as I'm the one that said I get it down to a gallon or so, that's only if I'm switching brands which isn't often at all. Otherwise yes it's always above a quarter tank.
1995 BMW 530i :)
kippster41493
What are peoples thoughts on this:
Yesterday I went to a different Mobil station than usual because it was closer to me, normally all the pumps say "up to %10 ethanol" on this pump the mid-grade and low-grade said "10% ethanol" and the premium octane only had "7% ethanol". Is that "guaranteed" 3% difference worth going from mid-grade to premium?
1995 BMW 530i :)
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
You should be using premium regardless. As for the ethanol content, I've yet to see any substantial evidence that it's a concern. If it were more readily available I would run e85.
clifford06
Year and Model: 2000 T5
Has thanked: 6 times
Been thanked: 4 times
Post by clifford06 »
Greetings. I use Chevron from my neighborhood station. No Valero, 7-11, Racetrac or "mom and pop gas/ tax prep / hot sandwich " stations. But Shell seems to make performance better in my car and Dodge Ram 1500.
