That looks like its headed to the air cleaner for the heated air riser - there should be two nipples close together with a vacuum line on each
Look under your hood for the vacuum hose sticker with diagram.
Head gasket 2000 S70
- Has thanked: 1611 times
- Been thanked: 4074 times
michaelw84
- Year and Model: 2000 s70
yea its anon turbo and retightening was an option but since I was that deep it was foolish not to replace gasket anyway
clifford06
- Year and Model: 2000 T5
- Has thanked: 6 times
- Been thanked: 4 times
I feel what you're saying. You finding loose bolts gave me the idea of tightening before disassemble. I try and report back.
clifford06
I saw where you say loose bolts near cyl. 3/4. My leak is 2/3. This is pretty much the area of starting to " torqueing head bolts center to out " . I'll be sure to pay attention to this is head removal is needed.
- Has thanked: 17 times
- Been thanked: 35 times
A vacuum diagram for your car should be under your hood when you look up. See what matches up with your lines. Hopefully someone before you didn't take it down. Btw, that white line looks like one that might attach on the back side of your large accordion hose to your intake manifold. Look there to see if there's a nipple for it.
- 18 Replies
- 6397 Views
- 527 Views
Last post by erikv11
- 1451 Views
Last post by Florida Wheel
- 2604 Views
Last post by precopster
- 903 Views
Last post by Wvusaxplayer
