You can override immo2 ecu on mot 4.4 car with chipped key to start and run it without chipped key but you can't acces ecu in order to read the codes afterwards.
Even if you try directly from pin 7 obdII to b36 ecu you won't get communications because immo2 is missing.
With re-programmed ecu all of this should be different....but i'm not sure.
Adding an OBDII Port to '95 850?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
See what? That I am correct and you're not?misha wrote:tryingbe wrote:...Hausmeister has a 850 with M4.3 ECU. He wants to use a M4.4 ECU and add an OBDII port.See?hausmeister wrote:Correct, I have an EU car, originally with M4.3, but I am using a reprogrammed (bought) 4.4 ecu. Everything works fine; I just want to read the codes. Immobilizer etc doesn't matter since the car originally came with 4.3
So best option ist to take apart the ecu "dock", maybe add the wire to A6 and also use this for obd2 port?
misha wrote: @Hausmeister....
You're right....but mot4.4 diagnostic won't talk without immo2 ecu.
AGAIN, NO. Maybe some m4.4 but NOT ALL. Self-tune M4.4 diagnostic can work WITHOUT an immo2 ecu.
I flashed a M4.4 ECU from the M4.4 wiki website and put it IN MY M4.3 car and OBDII worked JUST FINE. No immo2, no chip key.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- misha
Are you kidding me?
HE ALLREADY HAVE M 4.4 ECU INSTALLED IN HIS CAR!
He don't WANT to use it... HE ALLREADY USE IT!
SEE NOW?!
I didn't said that it won't work....it possibly just can't read engine codes...but that's questionable too since it was allready re-programmed.That's all.
All i said was about european M4.4 and hausmeister is from Europe...not U.S.
SEE NOW?!
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 277 times
- Been thanked: 85 times
Guys... seriously?
I think I clarified enough what I'm trying to do.
@Mods you can delete the whole thing if you want, it is kind of pointless, seems there is no easy way, and these 2 can argue over pm.
850 T5-R '95 auto
- misha
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 785 Views
Last post by Ozark Lee
- 14 Replies
- 4951 Views
Last post by crashtest
- 1132 Views
Last post by tryingbe
- 1003 Views
Last post by RickHaleParker
- 11 Replies
- 2669 Views
