Coolant leak
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 12 times
Re: Coolant leak
Post by sleddriver »
bmdubya1198 wrote:Lower rad hose is on the driver's side. That sounds like it's coming from the upper hose/thermostat area and dripping down. Maybe even the reservoir or return hose on the t-stat housing.
+1
Could also be a split t-stat gasket. Look for coolant stains around there.
If you're losing that much coolant, that quickly, to completely drain the reservoir every few days.....that's quite a leak!
M1 10W-30 HM
james321
Year and Model: 2000 v70
Post by james321 »
If I jack in up and get underneath will I be able to see it from under the car?
Thanks.
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
I would see a leak that big.
85 GLH, 367 whp
00 Insight, 72 mpg
sleddriver
tryingbe wrote:I would see a leak that big.
+1
M1 10W-30 HM
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
I don't see why not.
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 28 times
Post by cuhfs »
Have you tried pressuring the system. Many big name auto parts stores have loaner pumps. With engine off. pump at overflow tank to abt 8 to 10LBS and see where it is leaking from.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
beigg
Year and Model: 850 97
Post by beigg »
Cylinder leak down test and a dye test goes a long way for finding cooling system leakages regarding volvo's.
sleddriver wrote: If you're losing that much coolant, that quickly, to completely drain the reservoir every few days.....that's quite a leak!
For a pressurized system, it's quick to 'push' out, unlike an open/non-pressurized system.
ugh smh 850 Turbo fridge
