98 V70 Brake squeaks - don't understand the cause
98v70dad
- Year and Model: 98 V70
- Has thanked: 1 time
This morning before I drove the car I gave it a good bath since it was covered in road dust and I couldnt even see out of the back window. I gave the wheels special attention. The squealing is essentially gone now. I just drove about 30 miles and got one squeal which later went away. I'll keep my eye on it.
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
How about piston to pad squeal?
I just put on new pad front and back and was asked if I needed brake grease. I had never had an issue with squealing, so I said no. Bad Idea..Now most of the time backing out of the driveway I squeal. Not so much going forward, but some more now then before. I call this a harmonic squeal between the pad and piston, hence the brake grease. At some point I will redo and put the grease in, but other irons in the fire right now.
Just another thought.
Shane
Shane
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
98v70dad
obayha wrote:How about piston to pad squeal?
Shane
I grease both the back of the pads and the caliper pistons when I change the pads. Everything was done correctly 6 months ago by me.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
The problem 90% of the time.obayha wrote: I call this a harmonic squeal between the pad and piston, hence the brake grease. At some point I will redo and put the grease in...
Shane
- 11 Replies
- 2353 Views
Last post by jimmy57
- 1645 Views
Last post by xanthefin
- 1253 Views
Last post by sleddriver
- 764 Views
Last post by mydamnvolvo
- 19 Replies
- 2539 Views
