ABS controller revisited Topic is solved
Has thanked: 1609 times
Been thanked: 4065 times
Alldata maps P1551 to ECM510F, speed sensor signal
If you are using the code reader description of the code, they Are often wrong in my experience
The good news is you now have lots of spare baro sensors !
By the way, the light coming on at 25 kph is the ABS self test. At this speed the ABS burps and tests itself after each start. If the ABS has a problem, that's when the light comes on.
beigg
Year and Model: 850 97
Post by beigg »
abscate wrote:Alldata maps P1551 to ECM510F, speed sensor signal
For a 97 850, which wire is responsible for sending the self test signal?
ugh smh 850 Turbo fridge
Thats a mattymoo question. Asking me is like asking Forest Gump to explain KAM theory.
I think the self test is triggered internally when the ABS unit detects fast enough wheel spin to enable reliable speed detection but thats an uneducated guess.
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
There isnt one. It's the module itself is initiating the self-diagnostic, the module is really just a computer.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
This makes complete sense to me seeing as any scanner program will pull ABS codes through the ABS module, not the ECU. The ABS module does not usually trigger the CEL, from my experience.
Matty Moo
Has thanked: 1 time
Post by Matty Moo »
1996-1998, the abs system won't trigger the CEL, 99 and up it will.
2000 s70 GLT
2014 Ram
s70dean
Year and Model: 1999 awd 1998 t5m
Post by s70dean »
"1996-1998, the abs system won't trigger the CEL, 99 and up it will"
I suspected my old Autel was unable to read these codes properly which is why i ordered a newer Md802 to read the codes just waiting for it to arrive. So it's possible then my check engine is being caused entirely by the ABS controller problems? Kinda good news.
beigg
Post by beigg »
bummer. thanks for the confirmation!v
Your whole problem could be a wheel sensor or wire which is failing the ABS test
bmdubya1198
That's definitely possible. Can't you test those with a multimeter?
