Genuine Volvo ATF is NOT Mobil 3309...
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
T-IV is even thinner than Mobil.
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
I have trouble with that test. There may or may not be differences between these various 3309 spec fluids. But I refuse to form a conclusion on that. The fluid depth isn't the same between the little condiment cups (among other concerns).
vtl
Post by vtl »
In first video Mobil and Volvo have the same level, in second video Toyota and Volvo have the same level.
vtl
Post by vtl »
About a week since replaced the fluid. All gears except 3 are unnoticeable, cold or hot. 3 (mostly 2-3, sometimes 3-4) is erratic, it can shift smoothly one time and give a slight jolt another. I'll remove B4 servo cap and inspect what's inside. Pretty sure this behaviour is caused by B4 band/anchor/cover.
All the rest of transmission imperfections was totally cured by Volvo ATF. Plus the car pulls as equipped with a rocket booster :)
vtl
Post by vtl »
Ok, I've solved my 3 gear imperfection. I had a wastegate actuator shortened by 1 turn. Bought a tool from ARD, returned pressure back to stock 1.8 PSI. After 3 engine starts and maybe 20 miles transmission is fully cured, I drive a 12 years old car with 157k miles on the clock and a perfectly working original transmission.
Has thanked: 1609 times
Been thanked: 4063 times
Interesting Vtl. I know jim has warned people not to play with wastegate adjustment on late P80 and P2 cars, sounds like that's good advice
vtl
Post by vtl »
I had to back out 2.5 full turns to return to stock pressure sensitivity, while I did 1 turn only few years ago. Looks like wastegate gets tired over years and needs to be calibrated once in a while even if wastegate actuator was never touched.
Is that lengthening or shortening the rod?
vtl
Post by vtl »
Lengthening -> decrease wastegate activation pressure, shortening - increase.
mrbrian200
vtl wrote:I had to back out 2.5 full turns to return to stock pressure sensitivity, while I did 1 turn only few years ago. Looks like wastegate gets tired over years and needs to be calibrated once in a while even if wastegate actuator was never touched.
I need to do that too. However...
I've been paying super close attention to mine I might also suggest the CBV operation starts becoming inconsistent with air temperature/heat soak conditions etc as they age. Some of this adjustment may be compensating for altered CBV properties. As with the wastegate actuator, operation is a combination of both spring/air pressure and the physical properties of the diaphragm itself.
