1999 C70 CONV VIDA diagnosis (renamed)
redc70
- Year and Model: 1999 c70 convertible
- Has thanked: 9 times
- Been thanked: 5 times
Yes I used the whole system, Vida Dice 2014d I believe. There is also a step by step process to calibrate the top by taking measurements on all the parts involved by taking readings at the windows and top. I do believe that the dealer can only do that with a VST 2000. So, calibration might be a dealer issue only. However, I got the top error codes via the CAB module which in turn gave me all the error codes for the top. Things like tension rib opening and closing current too high, time condition error in movement, lock and cover lock faulty signal and that the top was in an invalid position. I think this all means it needs a calibration? If anyone has any ideas it would be greatly appreciated. The nearest dealer is in Houston and a 2 hour drive away. Still learning to use the software correctly and a long way to go.
- 23 Replies
- 2102 Views
Last post by volvolugnut
- 1943 Views
- 1655 Views
Last post by misha
- 689 Views
Last post by Gmac69
- 363 Views
Last post by 4717666
