Steering column replacement
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Pulled the steering column out of a '95 today. Took about an hour. Send me a PM if you want it.
Okay, so six months later, I finally got time to open up the casing and take some pictures. Now I see what the guy meant by "drilled out" and "needs new steering column".
Pictures!
This is what the column looks like from the outside: And this is what it is inside: from underneath: From the side: The guy says that the part will be about $150, and about $500-600 for labor. I say screw that, found the upper steering column on ebay for $50 (http://www.ebay.com/itm/95-96-97-Volvo- ... CI&vxp=mtr), will install it myself. However, is there anything I should know before I do that? Obviously, disconnect the power, but apart from that?
Pictures!
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
look for the advisements about the electrical connections "clockspring", make sure it is locked out properly.
edit-P.S. find a mechanic with more Volvo knowledge, or better yet, become that guy... this is the place to learn it.
Current Volvos:
- 1224 Views
Last post by Ou2mame
- 12 Replies
- 14581 Views
Last post by bronco
- 1522 Views
Last post by alschnertz
- 6561 Views
- 743 Views
Last post by MadeInJapan
