98 v70 right drive axle + wheel bearing replace
98v70dad
Year and Model: 98 V70
Has thanked: 1 time
Post by 98v70dad »
erikv11 wrote:I have dropped the control arms so many times, and never replaced those mounting bolts.
I ordered new wheel bearing bolts. The only reason I replaced the control arm mounting bolts was that I installed new control arms a few months ago and they came with new mounting nuts/bolts.
I would agree that the old ones were OK, but I say use the new ones if you've got them and they're good quality. I always save the old nuts and bolts since there may be a need for them some day. So far I haven't used any of them though. My supply is starting to take up some space.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
I see, yeah I would certainly swap them in if I had a set in hand.
On the spare bolts: Spare fasteners are great but but yeah the big ones don't get used so often. Wait until you have a couple sets of head bolts, too! Hard to justify dumping them, they are big works of metal art. I found a use for I think only one of them, to make a torque mount bushing press, the rest sit in their box waiting for a home.
98v70dad
Has thanked: 1 time
Post by 98v70dad »
erikv11 wrote:I see, yeah I would certainly swap them in if I had a set in hand.
I sometimes replace parts just because I have to take them off to do something else. If they are ones that will leave you by the side of the road when they fail replacing them is worth the money for me. It could be considered a waste of money but I figure that missing a day or two of work because my car is out of service is way more expensive. Even so, the car really doesn't cost me much to operate.
Has thanked: 1609 times
Been thanked: 4064 times
That's the essence of the "Preventative maintenance " strategy.
Running 5 cars with 7-9 drivers, for instance, if I need brake pads, I'll do pads-calipers-rotors. That pushes my costs up but that means no,labor or bills for at least 4 years on that car.
98v70dad
Has thanked: 1 time
Post by 98v70dad »
I agree. If the parts are close to the failure time its cheaper and less trouble to replace them early. Its knowing when that's key. That's the tough part.
I completely missed this important point
The ball joint nut and bolt is a torque to yield, or at least the torque spec is high enough that it definitely stretches.
Volvo would not sell me the bolt/nut combo without buying a ball joint or control arm. I used a 8.8 grade hardware bolt and washers and inspect it regularly. This is a critical piece of hardware so you might not want to remove the ball joint if you want to keep things kosher.
If anyone has sourced the bolt/nut combo please post
Parts for the ball joints here, these are single use, TTY
988815 bolt
987891 nut
No idea why Volvo would not sell them to me separate
greg850r
Year and Model: a long list
Has thanked: 5 times
Been thanked: 26 times
Post by greg850r »
abscate wrote: 08 Feb 2017, 07:38 If you need new bearing bolts PM me quickly - I know I have spares. They are also single use.
Ball joint nut/bolt - single use
Spindle to strut bolts ?????
I didn't know this. I've been re-using bearing and ball joint bolts for as long as I've been working on these things. :roll:
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
