The sign that the car runs better without it than with it connected points to a bad MAF.
It could be that connector needs to be zip-tied.It's common failure on this cars.
Other than that,you have a huge vacuum leak somewhere or your new MAF is bad right out the box.
New MAF, black smoke and stalling.
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Re: New MAF, black smoke and stalling.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
My guess would be that there is a hole in the turbo pressure system, between the turbo and intake.
- Has thanked: 292 times
- Been thanked: 765 times
This. Check the intercooler hoses for small splits, and for loose clamps.abscate wrote: ... Thats a turbo car, right? If there is the slightest leak in the induction hoses, after MAF but before throttle body, it won't run well with the MAF connected.
Everyone is saying the same things: bad Bosch MAF (unlucky - get one from the junkyard to test) or intake leak.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
I replaced it with an OEM Bosch MAF so that's been ruled out. I'm checking today for vacuum leaks, non from the top but could be on the bottom.misha wrote:The sign that the car runs better without it than with it connected points to a bad MAF.
- misha
Did you try zip-tying it's connector:
You have few possibilities here:
-bad maf right out of the box(less likely)
-huge vacuum leak somewhere(more likely)
-bad maf sensor's connector(common fault on these cars)
Since you have been driving the car for some time with bad Maf,your o2 sensors are fouled with soot and not able to work properly.There is possibility that Cat is also clogged.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- rspi
Contact rspi..
Also, make sure your intercooler is not cracked or split on the bottom of the car. I purchased a car that had a large chunk missing from the intercooler.
- RigsPGT
- Year and Model: Red 99 S70 T5,
- Been thanked: 2 times
I'm afraid you might have bought or sent a MAF from a naturally aspirated car. Do the part numbers match on the new one? Now either you have a bad new MAF or a wrong one due to web site errors. If unplugging it the car works good then we can rule out any other things with the car itself and point the fault to the MAF. I drove more than 100 miles on a bad MAF plugged in without having a CEL being tripped.
99 S70 T5, The Red Devil
Ported 19T and R manifold, 3" DP with Magnaflow race cat, 2.5" cat back, Precision FMIC, Rigs intake pipe, H&Rs, Bilsteins, 302's with Akebonos, Jewels, HIDs, egg crate grille, transmission cooler.
- misha
RigsPgt.....Maf sensors are the SAME for na & turbo cars from '96-'99.....erikv11 allready pointed that out to you.
Bosch # 0 280 217 107.
'99 & '00 have different ones but still the same for na & turbo...and it would be Bosch 0 280 218 108.It's connection is different too.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
From what I've learned, the MAF is the same for the turbo and normal model. When either MAF is plugged in I get no CEL light, just runs incredibly rich. New MAF at least will hold an idle, with the old MAF it won't idle longer than a few seconds.RigsPGT wrote:I'm afraid you might have bought or sent a MAF from a naturally aspirated car. Do the part numbers match on the new one? Now either you have a bad new MAF or a wrong one due to web site errors. If unplugging it the car works good then we can rule out any other things with the car itself and point the fault to the MAF. I drove more than 100 miles on a bad MAF plugged in without having a CEL being tripped.
- 7062 Views
Last post by enriquepr21
- 1611 Views
Last post by matt5112
