I just replaced all the coolant hoses and completely agree with erickv11. That lower turbo hose can be a bear to remove and since you pretty much have to strip the left side of the engine to get access, if it's in the budget I'd replace the heater hoses also. Classic case of WIIT. WHile I'm in there!
Gordon
Bad coolant leak
Jaguar xjs
- Year and Model: 1996 850 turbo
1996 850 turbo
1994 Jaguar XJS 4.0
1976 Triumph TR6
2012 Scion Xb
1994 Jaguar XJS 4.0
1976 Triumph TR6
2012 Scion Xb
- Has thanked: 1614 times
- Been thanked: 4078 times
Ive got a spare turbo outlet hose, Volvo OEM
- Been thanked: 504 times
I posted the PNs for the Turbo coolant hoses and the tips/tricks in the thread below.
Do NOT buy URO or aftermarket hoses!!!
Stick to Volvo OEM hoses, which are not expensive at all.
DIY: 1998 S70 GLT Turbo Coolant Hoses and 2 Radiator Hoses
viewtopic.php?t=55306
- Has thanked: 312 times
- Been thanked: 818 times
Heater hoses I would inspect and probably only replace if they seem to be aging poorly. Those factory hoses are superbly well made, they fail rarely so if they look good they probably still are. I'm not sure the newer heater hoses from Volvo are the same high quality (abscate may have some comments about that point).
But whatever you do, do not buy aftermarket heater hoses, unless you decide to do one of the ghetto swap methods (uses regular heater hose, not the pre-formed ones with the metal nipples).
- 16 Replies
- 4572 Views
Last post by granite
- 16 Replies
- 5469 Views
Last post by lcc014
- 1701 Views
Last post by DanSC
- 4145 Views
Last post by SuperHerman
- 12 Replies
- 2866 Views
Last post by greg850r
