2000 V70 front seat repair questions?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
benpineapple wrote:About the wire retaining strips for the hog rings...I redid my lower seat skin a couple weeks ago, and a couple of the wires had pulled through the foam. I used a screw driver and jammed 2 holes clean through to the bottom (on either side of the retaining strip) and pushed some wire through, looping it back up the other side. I did 3 of those "loops" to hold the retaining wire to the foam. Been sitting on it for a few weeks now, no issues. Glad to have it sealed up.
I was going to suggest the same. Robert has a video on this I remember watching a while back when I replaced the lower cover on my driver's seat.
Has thanked: 2215 times
Been thanked: 1853 times
Robert has a video for everything! I'll have to have a look at it. Thanks for the heads-up!
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
Neil have you seen Lee's tips on the wiring?
viewtopic.php?t=24633
No, not seen that thread. I know most of the issues, but I was trying to find out if there was an easy way to check the seat heater out of the car. I already had the 2 seats dis-assembled before thinking of swapping the seat pad due to the original being trashed. Then I know whether I am swapping pads or trying to fix original. Also it would help me and others pulling seats at junkyards as there is no power on the cars to know if you have a good seat heater or not.
So I think I have most of the issues covered now. The original seat base cover should be re-stitched and ready for collection on Monday, and tomorrow I will look at the foam swap or not or fixing the existing foam as per Robert's video and as suggested by others here.
The only real issue left to figure out is how to remove the lumber support knob so I can remove the seat back cover. Anyone know how to do this?
I looked at Elwoods instructions but couldn't get them to work as stated previously.
Thanks,
Has thanked: 1614 times
Been thanked: 4078 times
Once you find the right connector, seeing 2 Ohms resistance will pretty much confirm the element is good. 99% of the time they will fail to open, I.e. Infinite resistance
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Neil -- The lumbar support is a twist out, then pry proposition. You'll feel like you are on the verge of breaking something and swear that the plastic is about to disintegrate, when it will just release and come out. Be gentle. It is a bit nervous-making since as you are doing it you are sure this can't possibly be the way it comes out, but it is.
See if Bob Elwood has instructions posted on the Elwood Industries website. Those are the instructions I used successfully.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
abscate - Tested the original and it gave 4.4 Ohms and the 'spare' gives 2.7 Ohms so I'm assuming from what you have said that would appear to be good. Tomorrow I will hopefully get the cover back re-stitched and then can work on re-assembly.
Evan - I was using the Elwood info, but it gives the impression you:
1) Turn the knob CCW as far as it goes
2) Pull the knob out which 'locks' the slumber support in place
3) Continue turning the knob to remove it.
I will try your method. At least I have a spare seat so if I break something then I can hopefully figure out what I did wrong.
Thanks for the help guys!
