UPDATE i drove the car with 'incorrect part number module' and IT WORKS, well the ABS works, only thing that does'nt work is the "tracs" button which has to be held pressed to turn off tracs..
So correct Module for my car is 9162675 but i have fitted module part 9140773, driven the car for 30minutes to the beach and back and nothing seems fried..car is 1998 V70 t5m
WRONG ABS Module WORKS :D
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
- darylrobert
Part numbers.
Volvo has a habit of giving one part several different part numbers. I'll list them here.
All 96-98 FWD cars with TRACS. 850, V70, S70, C70. 9162675, 9140774 and 8602266. All of these are identical and compatible with each other.
All 96-98 FWD cars, non-tracs. 850, V70, S70, C70 9140773 and 8602265. All of these are identical and compatible with each other.
so it appears swapping 9162675 tracs unit with 9140773 non tracs, ABS works but no tracs
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Only and ONLY if they are succeded.That means that old number is considered obsolete and new one replaced it.That is all well known in volvo parts catalogue or database and there is not a single chance of mistake.darylrobert wrote: 06 May 2017, 00:55 ...Volvo has a habit of giving one part several different part numbers...
You can't say that abs/tracs abs module is compatible with non tracs abs module,if tracs doesn't work with it.It doesn't work because it have NO tracs option.Therefore,it is NOT compatible.
You can install a different part number ecu to your car.It will run...but it will NOT run properly and will have check engine light ON.
The point that it would run with it with a fault doesn't mean that it's compatible with it.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
On a 96-98 car the abs module isn't tied into engine management or the transmission. There's no communication between the two. On a 99-01 it is tied into the trans ecu and the only part of the ecu it works with is regarding the throttle on the stc units. The car is only looking for a compatible unit, it doesn't have any idea if it is supposed to have a TRACS unit or a non-traction unit.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- misha
I was not talking about CAN protocol.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 1678 Views
Last post by volvooh
- 11 Replies
- 7326 Views
Last post by Vovoroom
- 1649 Views
Last post by Dzikiewicz
- 6130 Views
Last post by misha
- 1816 Views
Last post by Dimbor
