Meyle HD Control Arm Bushings, hydraulic?
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
It's the spring seat you that is the first of the cheap parts to fail, and typically squeaks like you describe (I think!). You can check at the the top nut, put a big wrench or pliers on there and gently rotate. If there resistance, the rubber is intact. But if you can turn it, the rubber has torn through and the spring seat is shot.
Strut mounts get creaky when the bearings dry out or fail. There is no definitive test but if you have someone turn the wheel left and right (best to park on slick cement) while you are looking at the mount from the top, you can see a really bad one will stutter and creak.
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
So I tried to twist the upper cap to see if there's any movement. Nothing. It's still pretty tight.
So I don't think that's the case... Will definitely try to set a camera low to the ground so I can record the sound.
Thanks guys.
Retired:
2015 Volvo S60, T5, 85K
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
It requires quite a lot of force,not just twist it easily.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Post by erikv11 »
By hand it seems like a lot of force too twist it, but with a big wrench it moves easily - start to rotate it, you will either feel resistance or not. I said gently just because you don't want to shred the spring seat if it's not already broken. I wouldn't rely on testing by hand (unless it is so bad it just spins easily), get a tool on there.
theWIFES_S70
thanks guys, I'll get some channellocks on it and report back... sigh, this sound has me so bummed!
Retired:
