Hi OEMish,
Thanks for your description of how to install an OEMish transmission cooler! I have a 2004 c70 and have the same symptoms you describe: rough shifting , hunting for gears etc..., but only when it warms up and is in stop and go traffic. I had the transmission serviced and computer analyzed with no improvement. My question is: did the cooler fix the problem?
Thanks again,
landandsea
V70 Trans DIY Cooler Upgrade - OEMish
V70 transmission cooler upgrade
- Botbasher
- Year and Model: 98 "R" & 03 T5 V70
- Been thanked: 4 times
Yes and No.
It did change it, but I think the trans was too far gone for this Hail Mary attempt. I resolved myself to replacing the valve body once I could find a nice "C" donor wiring harness!
Good luck with it!
Ken
Good luck with it!
Ken
Never become a pessimist. A pessimist is correct oftener than an optimist, but an optimist has more fun, and neither can stop the march of events.-Heinlein
We have met the enemy and he is us.-Pogo
If speed kills, do brakes give life??
landandsea
- Year and Model: 2004 c70
Thanks Ken,
Really appreciate the feedback! I've had my c70 for a couple of months and generally like it but can't rationalize the 5k to have the transmission rebuilt (car cost 4.5k!). The car has 92k miles, I think kinda low for transmission issues, so I was looking for an alternative solution.
Best,
Bill
Best,
Bill
- Botbasher
It really depends on the care/abuse given it before you.
Do a complete flush (search for it in here)... Then do a relearn. It made a massive difference for me. If that works better but you still have issues I'd suggest a valve body or at min the 3 solenoids, before diving in for a trans.
As long as it holds properly in each gear the likelyhood of it being other than those is pretty slim. Possible, but I always exhaust my options before diving in too deep.
Hope that helps!!
Ken
Hope that helps!!
Ken
landandsea
Hi Ken,
I had the transmission fluid changed and the computer settings redone at a transmission shop, they recommended the valve body be the next step, without guaranteeing that is the problem. Do you think I should try the servo B4 cover upgrade first?
Thanks,
Bill
Thanks,
Bill
- Botbasher
Was the trans shop a Volvo Specialist??
I ask, because dumping the pan fluid and stomping on a gas pedal, really doesn't help when they're at this level.
A full fluid change, 13ish liters, and a Vida/Dice relearn is the best hope before diving into the guts. I did the 5L version and a relearn and it did nothing... After reading a bit more I did a full fluid exchange and a VIDA relearn and it was a night and day difference. I'm not suggesting the shop was wrong, but if they're not a Volvo shop, they might not know enough. Replacing a trans is a sure way to fix issues... 100% guarantee!!!
If the B4 hasn't been done, by all means a do it!! It'll only help, but you sounds a little far past its known fixes. Still worth a try though!! Takes about an hour... But you'll need to a VIDA relearn to make sure you get the most from it.
Ken
Ken
landandsea
Thanks Ken,
Your experience and wisdom are greatly appreciated. I'll find out more about the depth of the work I had done and, thanks to you, move forward with more insight. The c70 drove great today, 22 miles, no stop and go, rainy cool weather, and no issues. Part of me wants to ignore it, the other part of me can't. Bill
- 1589 Views
Last post by SuperHerman
- 17 Replies
- 6018 Views
- 2097 Views
Last post by fitz548
- 1916 Views
Last post by MoVolvos
- 11 Replies
- 6387 Views
Last post by foggydogg
