ABS Pump Motor Failure Questions
4cornersfan
- Year and Model: 2004 S80
2005 XC90: Left front brake locks up scary bad when I brake. replaced both front wheel speed sensors, calipers, brake pedal position sensor, and clockwork spring assembly, but it still locks up. Showing all kinds of codes even though I replaced the sensors. Should I try replacing the brake control module?
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
Sounds like a caliper issue. What codes return when you clear them?4cornersfan wrote: 02 Oct 2025, 17:02 2005 XC90: Left front brake locks up scary bad when I brake. replaced both front wheel speed sensors, calipers, brake pedal position sensor, and clockwork spring assembly, but it still locks up. Showing all kinds of codes even though I replaced the sensors. Should I try replacing the brake control module?
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- 44 Replies
- 16946 Views
- 1737 Views
Last post by CDoore54
- 37 Replies
- 17953 Views
Last post by 537playing
- 773 Views
- 19 Replies
- 3721 Views
Last post by sak54757
