Dropping engine for transmission removal - don't use S hooks
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
Well, that ended just about as well as my cousin's gate latch on his $300 Mazda Navajo's passenger door. It makes for an interesting ride...
abscate wrote: 27 Sep 2017, 15:02 Did find damage from this event today - I snapped off the dipstick handle. I will have it wired and welded before clutch is in though, as reminder.
I've snapped off my dipstick handle by moving wires around. I highly recommend Gorilla Super Glue.
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Are you putting in a new trans?
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Has thanked: 1613 times
Been thanked: 4078 times
new clutch
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
Snapping off one's dipstick could lead to a very bad joke. At least you're safe.
I know you use jack stands - you'd be surprised how many people assume a jack will never fail...
2023 Lexus RZ450e -66k
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
I managed to break not 1 but 2 engine accessory brackets while pulling P2 white blocks because I didn't use a load leveler to maintain straight chains.
Luckily in both cases it was when the motor wasn't up very high. Certainly scared me. They both broke at the thinnest point on the bracket.
I got my HarborFreight bracket aligned so,that the cast bracket is held straight, the steel bracket is on a slight angle.
Right now, waiting for parts, all the weight is on woodblocks under the motor
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 13 times
Post by sleddriver »
OP: Using your power as a mod, I see you deleted my post being critical of you using S-hooks. Touchy, eh?
Though it looks like it'll work, you found out what happens once sufficient force is applied. Further, the rating of the steel is very suspect; it may snap at any instant when loaded. Third, no open ended anything should ever be used in such a critical situation. It needs to be secured and closed to properly distribute the force.
You do get credit for posting what not to do as sudden displays of gravity when lifting engines & transmissions are not welcome.
Glad you learned your lesson!
Gravity: It's Not Just A Good Idea. It's The Law!
M1 10W-30 HM
Did I delete that? Don't remember doing that - are you sure it posted?
Ive got a pretty thick skin, so unless it broke forum rules (which happens about once a decade) we don't delete stuff here other than dupes.
On edit - I did a quick scan of mod logs and nothing showed up as deleted, so Im guessing it never posted.
bmdubya1198
abscate wrote: 02 Oct 2017, 18:23 Did I delete that? Don't remember doing that - are you sure it posted?
Or you're just covering up...
Alas, I don't have root privileges on mod logs. Even the NSA is rethinking root access to 20 year olds, after, um, recent events. Dumbdonkeys
