1999 V70 PCV Vent Hose 1270321 - Discontinued!
Has thanked: 1611 times
Been thanked: 4072 times
I think I have the PCV off my 99 base parts car, it's broken but might help you sort out the pieces for a repair strategy.
I'll check the parts bin later today and see what I have
Well its a 10mm ID Plastic pipe running inside that foam exterior. The rubber ends have 13 mm ID on the PCV can end, and ??on the other end.
The thin vacuum line pulls off the elbow and has a 6mm ID on the other end. I doubt it would screw things up too much if you used a 10mm ID hose and maybe re-sued the end with the vacuum attach point or I can send you mine. It does look like new.
krenekj
Year and Model: Wife says too many
Has thanked: 2 times
Post by krenekj »
Thanks Abscate - much appreciated.
Is the large elbow that also connects the small vacuum line a separate part? You make a good point that I may be able to reuse that larger hose, and just replace the smaller one.
Thanks again! I'll let you know if I want to purchase the spare you have.
93 240 Wagon
99 S70 NA 5sp
02 V70 NA
18 V90CC T5P*
It's all one piece. The small vacuum line attaches to the elbow with some kind of office inside.
It's a freebie, I would probably cut it down to fit in a small box though.
I took photos before I travelled but they didn't stream this morning so give me a day to sort out
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
I would call them up,and make sure they actually have it
smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
Just to update this, MTC lists one on amazon that i put on my car which is total junk.
https://www.amazon.com/gp/product/B01CG ... UTF8&psc=1
MTC 171123/1270321 Breather Hose (Volvo models)
Two elbows cracked within months and it gave me erratic RPM issues at idle and when coasting to a redlight in neutral. Do not buy. Now i have to source a new one and remove my intake manifold to redo this job.
07 V50 T5 AWD M66 ~146k miles
amblerman
Year and Model: 1999 s70
Been thanked: 70 times
Post by amblerman »
I actually made mine out of copper pipe, elbow fittings and short sections of rubber hose from home depot.
All the copper was soldered after dry fitted.
if if I have to do it again, I'll just use rubber hose.
This was one of those projects that started with "This will be really cool" that turned into a "Why didn't I just do this normally???"
-A
duke1
Year and Model: 855 1994 10v
Has thanked: 416 times
Been thanked: 34 times
Post by duke1 »
callahanoffroad
Year and Model: 1995 850
Has thanked: 16 times
Been thanked: 53 times
Post by callahanoffroad »
amblerman wrote: 02 Sep 2020, 13:36 I actually made mine out of copper pipe, elbow fittings and short sections of rubber hose from home depot.
-A
I did the copper pipe after having a bunch of heater hose go bad. It would swell shut from the oil and vacuum pressure.
Author, Chef, and Shade Tree Mechanic
1995 Volvo 850, Non-Turbo, VVIS, LH FI, Green, 215,000 miles. B5254FS engine. Herman. viewtopic.php?f=1&t=84393
1996 Volvo 850, died at 280,000
Founder of: CookingForChemo.Org
Read my Silly Comic Book at: therealpizzabros.com/
