1993 850 RPM pulsing up and down at idle Topic is solved
VolvoMis
Year and Model: 96^850.20 95^850.25
Post by VolvoMis »
Check your exhaust manifold and o2 sensor if you have one.
Paul-93-850
Year and Model: 1993 850 non-turbo
Post by Paul-93-850 »
"Check your exhaust manifold and o2 sensor if you have one" is a rather vague suggestion.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
I believe he meant check your exhaust manifold for cracks (which you'd probably hear). As for the O2 sensors, I don't know how to go about checking those on a non-OBD2 car. That's something you would have to do some research on.
Paul-93-850
bmdubya1198 wrote: 26 Oct 2017, 15:13 I believe he meant check your exhaust manifold for cracks (which you'd probably hear). As for the O2 sensors, I don't know how to go about checking those on a non-OBD2 car. That's something you would have to do some research on.
Posting on forums is research. Hoping that a Volvo genius reads this and has something specific. I really don't have the money to buy part after part hoping to get lucky.
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
No one suggested you just replace parts. Testing and verifying a part is defective when possible is key. Here's a great link:
http://lmgtfy.com/?q=How+to+test+oxygen+sensors
bmdubya1198
wizechatmgr wrote: 30 Oct 2017, 02:20 No one suggested you just replace parts. Testing and verifying a part is defective when possible is key. Here's a great link:
Exactly. We can't do everything for you. We're here to help, but it's not up to us to spend time reposting things that are already fairly easily accessible.
Paul-93-850
The entire problem was vacuum leaks. Nothing to do with the MAF or re-manufactured MAF.
I replaced the rubber ends on the small vacuum hoses using pieces from a roll of 5/32 vacuum tubing that I had sitting around. I replaced the intake manifold gasket, the PCV hoses, the vacuum tree, the brake booster hose etc. Removing the intake manifold and the EGR was not easy or pleasant.
bmdubya1198
The intake manifold is much more of a pain than you would think on these cars. Glad you got it taken care of!
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Smart move replacing all of the 20+ year old vacuum lines. And thanks for telling us what fixed it!
Has thanked: 1609 times
Been thanked: 4064 times
bmdubya1198 wrote: 20 Jun 2018, 08:19 The intake manifold is much more of a pain than you would think on these cars. Glad you got it taken care of!
It’s a “ right tool selection” job
With a 1/4 inch ratchet, wobbles, and a collection of extensions it’s quite a snap. Add in a magnetic pickup and some grease to stick bolts into sockets and it’s practically a cake walk. Ok, maybe a cake jog.
