Jim, put an ear to the front of the engine. Down low on the front too, around the intercooler. You might be able to hear the leak. A stethoscope will help. Or a smoke test to see where it's getting drawn in.
Erik's post is as good a theory as any on how the engine management works in this unmetered air condition.
To add to it, when you go past 1/2 throttle, the already heavily trimmed (to +++fuel) state just goes off the map entirely. It's already way out of normal, probably even at idle.
I experienced exactly this. 1/3 throttle it was fine, but when the turbo spooled, stumbles, coughing, no power. Like an old car with choke activated while warm.
I can't remember what codes I got, but I'll look back at my photos. (I used photos to take "notes", like shots of the OBD scanner.)
SOLVED 96 Volvo 850 rpm's "governed" at 2.5k Topic is solved
- Has thanked: 2866 times
- Been thanked: 1332 times
Oh yes, I remember now.
Rereading my Volvo 850 Blown Intercooler thread:
No codes.I'm getting around 15mpg around town and NO CODES. A BLOWN INTERCOOLER triggers no codes. I learn something every day, I guess.
Another possibility: the wide, short hose on the throttle body blew partly off.
- Has thanked: 312 times
- Been thanked: 818 times
And that final intercooler hose, on the throttle body, also has a bad habit of splitting in a way that the split opens up when the rpms get high.
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
I edited the first post as to what I found, as follows:
thanks to the MVS wizards who pointed out where I should be looking. Neil, abscate and Erik filed some clues; Matt hit the bullseye recounting his own 850 turbo experience.
On mine, the lower hose on the intercooler had come loose and was about to fall off the nipple. A nice 5 minute fix and now back to full strength
- Has thanked: 2215 times
- Been thanked: 1853 times
Glad you found the issue and it is nice to get a cheap and easy fix too! Well done.
- Has thanked: 1613 times
- Been thanked: 4078 times
Nice - Volvo Horns for you.
Rinse repeat of mine last year
viewtopic.php?f=1&t=76489&hilit=1999+induction+leak
Of course, if I had been maintaining this car on a preventative maintenance (PM) basis instead of run to failure (RTF) , I would have replaced those nasty hose clamps years ago and saved myself hassle.
