Losing power for a month, now no start. lots of codes
scottinalaska
- Year and Model: 2004 XC90
Sorry about that. This is WHAT I FOUND. I haven't done a darn thing yet. I was just perplexed how it appears the cams could be so far out of time. AND, if they are this far out, likely I have smashed some valves. That's all. Thoughts?
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
I don't know how far off either of the cams can be before there's risk of piston/valve collision.
Add to that the gear that drives the belt may not be sitting properly on the crank.
You won't know without a proper assessment. If you take it to a dealer or indie make it clear that the nut at the crankshaft damper was missing for an unknown amount of time and that the splines which hold the alignment of the timing gear to the crankshaft are in question.
scottinalaska
Thanks for asking, mrbrian. I haven't done a thing. This is just what I found so far. And if the cams are that far off, it makes me assume that the valves are likely already bashed. Sad. Thoughts? Thanks.
- 16 Replies
- 4254 Views
Last post by zmf
- 981 Views
Last post by mrjacobrussell
- 1098 Views
Last post by cn90
- 1736 Views
Last post by oragex
- 4565 Views
Last post by jonesg
