Trickle Charge idea for Winter.
- Has thanked: 1611 times
- Been thanked: 4074 times
I think you will need at least a 5W panel or so to overcome self-discharge. VW actually ships it s cars with a 5W panel - or they used to,
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
You could tap into the battery at the back of the radio harness as well.
Also useful for GPS trackers when you have a user of the vehicle in the family with a history of substance abuse.
2023 Lexus RZ450e -66k
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
I found the yellow connector, can I use a jewlers
Screwdriver or should I use a t tap.
Or find a male blade, that would be easiest, does anybody know the size?
Thanks all
Thanks all
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
mecheng
I found a solution from an old O2 sensor, I will post a video of the final product later.
There are a couple of tricks and only 1 wire is live with the key off.
Make sure your accessory fuse is installed (in the engine bay, I believe no 16) , the P.O. removed it because it activates the power antennae which left me on a wild goose chase!
- IMG_8307.JPG (124.05 KiB) Viewed 1056 times
mecheng
I made a video showing how I made the constant power connection. Thanks for the input guys, works great.
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
Thanks. Good info
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- Has thanked: 2210 times
Love the creativity. I will look more into this as my V70R doesn't get used much and spends time sitting outside. The Viper protection and entry system drains the battery fairly quickly, so it would be good to be able to have a charging system that does not have cables tracking from the garage to the car and a trickle charger.
mecheng
Another reason I did it is so that I don't need to pop the hood and stress the cable, especially when its icy its sometimes difficult to open the hood. Last thing I want is a broken cable which many people have suffered from.scot850 wrote: 10 Jan 2018, 15:53 Love the creativity. I will look more into this as my V70R doesn't get used much and spends time sitting outside. The Viper protection and entry system drains the battery fairly quickly, so it would be good to be able to have a charging system that does not have cables tracking from the garage to the car and a trickle charger.
If I'm using my plug in trickle charger, I just run the small trickle cable in between the door jam, it sits against the rubber seal and doesn't damage it as it is such a small diameter.
Still it would be nice if there was somewhere you could feed the cable where it does not possibly chafe with time. But you make a good point on the cold weather and hood release. I have considered running the cable through the grille somewhere to again prevent opening the hood. Volvo used to have a plug point you could fit to the side of the bumper with a cover that the block heater could plug into so the hood didn't need opened. It may have been a European option only, not sure.
- 9409 Views
Last post by Rattnalle
- 17 Replies
- 10580 Views
Last post by volvolugnut
- 1912 Views
Last post by RickHaleParker
- 682 Views
Last post by jonesg
- 597 Views
