Trickle charging
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
Check to be certain - a friend with a P2 is back in town after 6 months gone - his battery is near dead. I have a smart trickle charger - is it safe to charge the battery while it is still hooked up, from the under hood terminal?
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- RickHaleParker
- Been thanked: 979 times
It is safe to charge with the battery hooked up but it would charge faster if the battery unhooked from the car. If it is flat dead it might take weeks to bring the battery back to life longer if you leave it hooked up to the car. It will also charge faster if you do the charging inside where it is warmer.
Active
Past
Past
azureblue
Thanks - I was going to loan him my charger, so I want to make sure he does it right...
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
If it sat for six months it’s likely the battery is dead beyond recovery. You need a fancier charger with the modulated voltage to revive a sulfated battery
- RickHaleParker
He has a smart trickle charger. A smart trickle charger with a pulse mode is what I used to recover that Volvo junkyard battery from 150 mv.abscate wrote: 24 Apr 2021, 18:46 If it sat for six months it’s likely the battery is dead beyond recovery. You need a fancier charger with the modulated voltage to revive a sulfated battery
Let him play god, bring the dead back to life.
Active
Past
Past
- 1903 Views
Last post by RickHaleParker
- 595 Views
- 42 Replies
- 6517 Views
Last post by crlande
- 7259 Views
Last post by JRL
- 2273 Views
