98 S70 non turbo loss of power
45DegreesPDX
Year and Model: 1998 S70
Has thanked: 1 time
Post by 45DegreesPDX »
Just pulled out the spark plugs, and I'll definitely be replacing them.
I also noticed a crack in my alternator, think this could be an issue? I'll definitely replace it, just trying to see if it might be a source of my symptoms.
WhatAmIDoing
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
Yeah, those spark plugs are pretty well toasted. How do your plug wires look? That crack is definitely not good. With the engine running, check the voltage of the battery with a volt meter. If it's under 12.5V, the alternator is likely not supplying adequate power. And make sure you pull the distributor and check that as well.
45DegreesPDX
Has thanked: 1 time
The plug wires look okay, nothing too out of the ordinary, but I figured I'll replace them anyways while I've got everything taken apart. I'll be able to check the cap either later tonight or tomorrow. Am I looking for dirt and grime or just damage in particular?
WhatAmIDoing
You are looking for dirt, evidence of arcing (google arcing in distributor), and wear on the pins and rotor. Post a picture if you can and we'll tell you whether it looks good. I'm guessing it's probably time to replace.
45DegreesPDX
Has thanked: 1 time
Yeah, it looks likes its time to replace these.
Also, when I was taking off the airbox, I accidentally broke what I think is the preheat hose that connects to it. Is this easy to replace that I can do myself with some clamps?
Thanks for all your help!!
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Yeah, plugs, cap and rotor could stand replacement. The crack on the alternator is just on the plastic ring though, right? If so, not critical
Current Volvos:
WhatAmIDoing
I agree with FLXC90. Time for a tune up: new plugs, wires, cap, and rotor. Only use Volvo, Bosch, and/or Bougicord (wires) for these parts. FCP sells some good tuneup kits using OE parts.
45DegreesPDX wrote: 27 Feb 2018, 00:38 Also, when I was taking off the airbox, I accidentally broke what I think is the preheat hose that connects to it. Is this easy to replace that I can do myself with some clamps?
You mean the rubber elbow that connects to the white line? I have a turbo, so not sure what all hoses run to/near the NA airbox. Picture would help.
45DegreesPDX
Has thanked: 1 time
No it's silver and rigid. Looks similar to a dryer hose connection and connects behind the engine near the firewall to the exhaust system. I'll post a picture tonight.
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
Broke preheat hose is of no consequence, take your time on it, and yes you can easily DIY replace this no-clamp hose. You can get a generic replacement from Autozone or similar (I know they have them at Advance Auto and O-Reilly's, around here).
For where you live in Portland OR, you could also just throw away the preheat hose and inside the air box wedge the flap permanently to the "cold" (outside) air side.
WhatAmIDoing
45DegreesPDX wrote: 27 Feb 2018, 16:12 No it's silver and rigid. Looks similar to a dryer hose connection and connects behind the engine near the firewall to the exhaust system. I'll post a picture tonight.
Oh that hose. I wouldn't even worry about it. It's hardly important. Should be easy and cheap DIY fix.
