XC70 Immobilizer, won't start, not antenna/CEM/ECM
YossarianZ
Year and Model: 2007 XC70
Post by YossarianZ »
I got my CEM/ECM back from xemodex, trying to connect VIDA/DICE again. In the meantime I just noticed there was a 25amp fuse for the AWD system in rear fuse box. That was the original reason I took the car to the shop, and they said they fixed it with the fuse. It's supposed to be a 7.5amp fuse. It's easy to imagine that there was some deeper electrical problem that replacing the fuse covered up, and it being a fuse rated for more than 3x the current... some damage could've been done on that test drive.
Shit
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The AWD is usually the pmp or the DEM. Not bad to replaced (not all used DEM fit, Xemodex may have a #number compatibility list)
YossarianZ
I disconnected the DEM and engine still will not start. VIDA still cannot read anything from the DICE box. I get blinking lights indicative of a good connection, but absolutely no reading ever. Nothing with other OBDII sensors either.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Plug the DiCE into a USB port and use the stand alone DiCE diagnostics application to find out if DiCE is working.
If DiCE diagnostics is not installed, "Vida insulation Media":\3PP\Products\DiCE\SetupDiCE.exe
Sometime just running SetupDiCE.exe will correct a communication problem.
Active
Past
YossarianZ
RickHaleParker wrote: 01 Apr 2018, 14:24 Plug the DiCE into a USB port and use the stand alone DiCE diagnostics application to find out if DiCE is working.
Ran a diagnostic in the Vida software and all results were good.
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
This is why it's always best to read faults first then proceed with suspected repairs. Does driver's display say "Starting prevented" or similar?
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
Can you see if the DiCE will light up when connected to the OBDII only (no USB to computer)? If not then the 12 V on the CARB connector isn't there, you may want to look for a recessed/broken/bent pin just in case, or a blown fuse
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
RickHaleParker
"Nothing with other OBDII sensors either."
"Ran a diagnostic in the Vida software and all results were good."
I'm beginning to wonder if the shop knock a CAN bus loose are failed to reconnect a CAN bus.
Active
Past
precopster
Failure to connect canbus will result in modules appearing red in Vida diagnostics.
Choose Network and choose each module in turn to see installed software. This way determines if Canbus reaches all modules.
As I mentioned earlier what does driver's display say when car won't start? If no message is present the key is matched to CEM/ECM
azureblue
Year and Model: 2014 S60 T5
Has thanked: 16 times
Been thanked: 8 times
Post by azureblue »
I would disconnect any module that was messed with and check the pins very carefully, to make sure they are all in place. Check And check all related fuses and relays, too. To me, that seems to be a good reason why the car just dies on the road. But I suggest contacting Henry. He and his protege have the software to see pretty deep into the computers, and they really know what they are doing... First hand experience speaking
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
